Will travel change on Vanilla fork change geometry?- Mtbr.com
    HammerHead
    Reputation: Gevorg's Avatar
    Dec 2004
    I have 2006 Fox Vanilla RL with 130mm of travel. It has 19.5" distance from axel to crown. I want to change its travel to 100mm using spacers per Fox manual and install on my XC bike. However my XC bike manual says that distance from fork crown to axel should be 18.5"
    So I am wondering if I change the travel from 130mm to 100mm will that also reduce the distance from axel to crown on my 2006 Fox Vanilla RL so it does not change the geometry on my XC bike
    Any input is appreciated.
    2012 Cannondale Flash Carbon 3 29er
    2013 Tarmac Sport
    2009 Langster Moscow
    "What is wrong?"
    "You need a new bike"
    Reputation: Hardtails Are Better's Avatar
    May 2005
    Yes. This will drop the a-c 30mm, or 1.18". That'll be about right for your XC bike.
    HammerHead
    Dec 2004
    While on the subject. Do I need to order part form Fox, or just moving the existing spacer from one side to another will work. Also how hard is the process itself. Anybodye else done that
    2013 Tarmac Sport
    "What is wrong?"
    HammerHead
    Dec 2004
    Well after a bonehead mistake, I eventually changed the travel it was easy. I also replaced the coil to a stiffer one. Now I have 100mm vanilla fork. Will test it this week.
