• 05-01-2015
    ducimus
    Will a Rock Shox Vivid/Kage Rear Shock Spring fit on a Fox Van R Shock?
    Like the title says...does anyone know if the Vivid/Kage spring will fit on a Fox Van R shock. I'm asking about coil diameters and such...
    Thank you...
  • 05-01-2015
    11053
    RS springs have a wider internal diameter than Fox.
    You can usually fit a Fox shock with an RS spring, but you may have a bit of slop without enough preload.
