why fox 450x2.80 shorter than fox 500x2.80?- Mtbr.com
Results 1 to 3 of 3
    Trying a little
    Reputation: dusthuffer's Avatar
    Nov 2006
    I have a fox 450x2.80 that is about 1/2 inch shorter than my fox 500x2.80.
    Is that normal?
    Is maybe one of the springs mis-labeled?
    I don't want to run the 450 if it really is actually too short
    I never apologize. I'm sorry, but that's just the way I am.
    Reputation: Hardtails Are Better's Avatar
    May 2005
    Normal. A heavier coil requires thicker wire. Therefore the overall length of the spring needs to be increased to allow for enough spacing between the coils to prevent binding. You're all set.
    Trying a little
    Nov 2006
    Thank you H.A.B.
