Why is this Air Fork so Cheap?- Mtbr.com
Results 1 to 31 of 31
    Oct 2018
    another member suggested that i upgraded my coil sprung 100mm fork to an air "sprung" 120mm fork.
    So i looked on Amazon and i found this.
    it seems like a deal for $150. where would buying this bite me in the ass?
    https://www.amazon.com/Suspension-Re...8-7&th=1&psc=1
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by The_Granny_Gear View Post
    Well, for one, at that price, it's going to have a very simple damping system, one that gets harsher and more out of control the faster you go.
    For two, there will be no parts available to fix anything that breaks, like a damper seal or top-cap or rod.
    There are likely no instructions for servicing and it may not even be possible to service the cartridge, so it'll slowly self-destruct.
    Basically, you have no idea what the internals of this fork are, the company has no reputation, no engineering drawings, no diagrams, no real specs, no support, etc. At this pricepoint, the chances of getting something that ticks the boxes to be a viable and reliable suspension component are not worth it, you'd be better off taking $150 down to the local casino and gambling it there. At that pricepoint, rigid forks are better. A rigid fork is always better than a poor suspension fork.
    Oct 2018
    alright, thanks for letting me know. what would you recommend for a low price point?
    A good used one that was well-kept, or a rigid fork. The issue with the low end pricepoint stuff is it gets worse the faster you go and is never as precise as a rigid fork, so I'd always go with a rigid fork over a low-end suspension fork. At this pricepoint, these are generally just suspension-fork-looking-objects. As far as the used fork or even "great deals" are concerned, this takes a certain amount of mechanical knowledge, both to the innards and damper theory, as well as servicing and maintaining. So that stacks the cards even more against you. Usually, the quality stuff that you'd want to keep on your bike that actually provides a benefit and allows you to grow as a rider is around $500-600. The stuff below that is often not worth it. Again, it's hard to make any hard rules here and there is too much to attempt to teach. Better for you to start doing some research on these ideas. At $800-1000, you will usually be getting something high quality that performs well for a variety of riders and conditions. This is usually better because of the potential and ability to keep up with your riding. Sometimes you'll find last years 800-1000 fork for 499-599 online. When you start "scrounging" for lower cost solutions, you generally need to know a lot of ins and outs of compatibility, servicing, design, etc...
    high pivot witchcraft
    Reputation: mtnbkrmike's Avatar
    Mar 2015
    Jeezus. Kashima.
    2021 Norco Bigfoot VLT 1
    2020 Kona Unit
    2019 Forbidden Druid
    2018 Kona Honzo ST 30th BDay SE
    2015 Kona Paddy Wagon Fixed Gear
    Underskilled
    Reputation: CaveGiant's Avatar
    A lot of high-end bikes are moving from air to coil.
    The cheaper the fork the bigger boost you get from moving from air to coil.
    Even ultra high end 3 chamber air springs are not as smooth as a coil.
    So why are you moving to air?
    Why would I care about 150g of bike weight, I just ate 400g of cookies while reading this?
    Aug 2013
    Quote Originally Posted by CaveGiant View Post
    They're really not, at least for forks. I'm sure there are some but I can't think of any decent bikes that are being sold with coil forks.
    Dec 2013
    He is asking for really low price point, at this level reliable damping would be far more important than coil/air spring feel.
    If I were you I'd keep an eye on ebay/craigslist and similar resale pages for reliable entry level fork like manitou machete, sr suntour axon or rockshox 30/judy. You might not be able to find one today but the biking season is almost over and now the bike rebuild/upgrade season will be starting so there will be options. Few years ago I managed to get pretty decent used Manitou Minute for like $60 on ebay
    Dirty Old Man
    Reputation: scatterbrained's Avatar
    Coils are good when you're descending enough that the change in altitude can effect how the fork feels at each end of the run. They're also great when you have a personal mechanic and a collection of springs so you can change them as you see fit. For the average Joe I'd say air is better. All you need to dial in an air shock to the right setting is a shock pump. If you gain or lose weight it's just a matter of adding or removing air, rather than buying a new spring. You can adjust an air spring one pound at a time too, I'm yet to see springs that are available in such small intervals.
    Dirty Old Man
    That doesn't even look like it has a tapered steerer tube. It's a cheap chinese knock off of a Fox fork on the outside, and WallyWorld level bits on the inside. Does your bike have a straight 1 1/8" headtube and quick release front axle?
    You should check out e-bay to see if you can pick up a used Fox 32. I'm seeing used Fox 32s in 120mm travel from $140 to $320 right now.
    Reputation: huckleberry hound's Avatar
    Feb 2015
    For a reliable inexpensive air with service parts available I suggest using the Suntour upgrade program and get a Raidon fork . https://www.srsuntour.us/pages/upgrade-program
    Change begins by doing something different.
    Quote Originally Posted by scatterbrained View Post
    Coil springs work over a WAY bigger range, you don't need to change them unless you gain or lose a crazy amount of weight. The fact that you dont need to adjust them 1psi at a time is a big benefit in itself.
    They also require way less maintenance. Forget zip tie burping, that's over forever with a coil. It's odd to suggest someone needs a personal mechanic for something that significantly reduces maintenance.
    Quote Originally Posted by One Pivot View Post
    Reputation: Darth Lefty's Avatar
    Sep 2014
    If it's a Suntour fork you have, Suntour offers upgrades at a reduced price.
    They also can sometimes be upgraded with a damping cartridge, but it depends which version you have.
    Or yeah, look out for used. Make sure which kind of steerer you have (tapered or not)
    I saw this piece of shit fork at my local shop. Some idiot bought it and brought it in because it wasn't "working" right. My mechanic was being really nice to the guy saying he bought a dud. I checked it out and it is shit. There is no damping, zero!!! No compression and no rebound. There is a lock out though. Stay away!!!
    Oct 2018
    Quote Originally Posted by Darth Lefty View Post
    unfortunately i have a non tapered steerer tube, but i'll look into suntours upgrade program
    Jun 2014
    Actually, I believe Suntour will upgrade from any fork, as long as it's OEM and you are the original purchaser.
    Dirty Old Man
    They work over a "way bigger range" in the way a pair of shoes labels "size 8-10" works over a bigger range than a pair of size 10 shoes.
    Rides all the bikes!
    Reputation: Sidewalk's Avatar
    May 2015
    I don't think discussing the pros and cons of high end suspension springs is much help to the OP. I don't think (s)he is in the market for an Ohlins...
    Dec 2017
    Yeah? How many $2000+ coil fork bikes are there on the market right now as completes? I would submit that there is no such trend as you describe.
    The fork in question has a straight steerer and 9mm quick release along with the utter lack of any support as discussed above. It is obsolete and doesn't fit any new bikes, so that also explains the low price.
    Oct 2018
    Quote Originally Posted by TwiceHorn View Post
    my fork came with my bike, so i'll see what i can do.
    If You didn't start on a Hardtail you're doing it Wrong
    Marz didn't even make different weights for some forks. RS typically did 4 or 5.
    You know this though. Whatsup with that? fox springs notoriously varies hugely between the same weight because it generally worked anyway.
    the half breed devil
    Reputation: shekky's Avatar
    Oct 2011
    Quote Originally Posted by Sidewalk View Post
    truth...
    Reputation: Heidenh's Avatar
    Feb 2019
    On a cheaper build I had going for a hardtail that came with a bad budget coil fork. I put on a Suntour raidon. It's a good fork, good for what im using the bike for, but in no way matches a 36 Fox Factory. The Fox just performs 20x better than the suntour and just plain gets me where I want to be on the trails. So in a sense, the fork you buy is going to matter a whole lot on what you plan on riding. So if you're going down the streets in people's lawn, or nearby walking trails. Some cheap budget forks may be what you'll want. But If you had some bigger trails with interesting tech to bounce over, you may want to invest in something a bit more 'made for the job'.
    Sent from my SM-N950U1 using Tapatalk
    Cycologist
    Reputation: chazpat's Avatar
    It's cheap so that you have some bucks left over to put toward your dentist bill.
    This post is a natural product. Variances in spelling & grammar should be appreciated as part of its character & beauty.
    Oct 2019
    I just put this fork on my inexpensive 29er and found it to be a HUGE improvement over what it had. Like a HUGE difference. That doesn't mean it is great or will win many races, but it rides way nicer than the crap fork that was on the bike when I got it.
    I am not going to put a $2000 fork on a $500 bike....nor should anybody.
    Oct 2019
    ...as for the safety, I have watched dozens of guys on $5000 bikes smash their faces into the ground because they didn't have the skills to match the bike.
    Feb 2015
    Quote Originally Posted by Crazy 8s View Post
    I'm sure it is an upgrade over the pogo stick of a fork that you previously had but did they give you a source for where to buy service parts like seals, etc. ? All forks require service after 50 hours of use.
    Oct 2019
    Quote Originally Posted by huckleberry hound View Post
    Fox charges $175 for a fork service, recommended after 125 hours of service. That is for 70cc of oil, a couple sponge seals and a few minutes of labor.
    They have endorsees and advertisements to pay for.
    I will likely ride this thing until it blows up and then buy a new one for $150...or maybe a carbon rigid fork because I am mostly just commuting with the bike.
    There has always been a great deal of irrationality in cycling...and no shortage of people that exploit it.
    Reputation: phantoj's Avatar
    You can get a new Manitou Markhor for about $200 on ebay, so that would be my preference over a noname.
    I would guess that some of the noname stuff is probably pretty good, but unless someone qualified buys one and reviews it, I'm not interested...
    EDR
    Reputation: eatdrinkride's Avatar
    Jun 2005
    About color difference and After sale Service:
    Different screens can cause the color of the item in the image to be a little different from the actual one. The allowed measurement error is +/- 1-3 cm
    This disclaimer would be enough for me to stay away. I hate it when my colors are off more than 1cm.
  1. Why does my cheap steel stanchion fork ride so nice?
    By KonradKlemmer in forum Shocks and Suspension
    Last Post: 09-20-2013, 04:44 AM
  2. Why so cheap?
    By jesse101 in forum All Mountain
    Last Post: 06-09-2011, 02:33 PM
  3. Air vs Air vs Air (Copy of the Coil vs Air ultimate...)
    By drakan in forum Shocks and Suspension
    Last Post: 09-13-2007, 11:50 AM
  4. disc wheelset cheap cheap cheap
    By InvictaS1 in forum Where are the Best Deals?
    Last Post: 06-05-2006, 05:48 PM
