Upgrades for 2020 Recon Rl?- Mtbr.com
Results 1 to 7 of 7
    Jun 2020
    I want to get some extra performance out of my fork but can't really raise the money for an upgrade right now. Can't find any information about possible upgrades for the fork online so I turned to the forum for some advice. If anyone knows anything or anyone, your opinion would be appreciated.
    Aug 2019
    Well, not sure if they changed it but you can get an extra 20mm of travel by removing a spacer in the air shaft side. That's about it for the Recon forks. Too bad you can't use tokens in them.
    Jun 2020
    I was wondering if you could swap in a 2018 charger 2 damper since it also works with 32mm stanchions? This one came up for sale on Pinkbike recently and seemed like I could get a good price on it.
    https://www.pinkbike.com/buysell/2809567/
    Sep 2019
    Do you have the steel stanchions or the Gold with aluminum stanchions?
    SRAM deliberately handicaps their cheapest forks to stop these kind of upgrades. 10 years ago it was not the case and you could, for example, upgrade your Recon's compression and rebound dampers to the best RS had on offer back then. I don't have specific insight on the current Recon RL but you will probably find obstacles like the top cap thread pitch being different from that used in the Sid, Reba & Bluto.
    Jun 2020
    Thanks for your insight. 98% sure I have steel stanchions, It's a shame that parts aren't compatible.
    Apr 2020
    If you do have a recon with aluminum stanchions, what dampers will fit?
    Sep 2019
    Quote Originally Posted by tstinchy View Post
    AFAIK the Recon Gold RL's internal stanchion diameter and thread pitch has been unchanged since the days of the Recon 3xx etc. in 2007 (but don't quote me on that - do your own research). The Recon Gold's compression and rebound dampers are common for 26", 27.5" and 29" wheel size and travel from 80-150mm.
    I *think* the best compression damper you can install is one of the 32mm Motion Control DNA dampers, either RLT (11.4015.544.110) or RCT3 (11.4015.544.130). Both of these dampers will give much better mid-stroke support than the basic MoCo damper that comes with that fork.
    But...the rebound damper in the Recon Gold is a basic port orifice design, and the above two DNA compression dampers will work better with the 32mm Revelation's dual flow shim-based rebound damper (11.4015.545.030 - good up to 150mm travel).
    https://forums.mtbr.com/shocks-suspe...l#post10410364
    https://forums.mtbr.com/shocks-suspe...er-955744.html
    If you want more certainty, unscrew and remove your compression damper and measure the cap's thread pitch (you'll need a thread pitch gauge). It should be 1mm for the above dampers to thread into the fork. Then use a caliper and measure the diameter of the motion control damper on the lower o-ring (without compressing the o-ring). The diameter should be 28mm for the above dampers to fit in the stanchion.
  1. Help needed with 2020 Recon RL travel
    By Semmtexx in forum Shocks and Suspension
    Last Post: 1 Week Ago, 11:16 PM
  2. Recon RL or 30 Gold RL
    By Grahammcs in forum 29er Components
    Last Post: 03-22-2019, 10:29 AM
  3. 2010 Recon Race 120 vs 2011 Recon Gold RL 120
    By mmckechnie in forum SRAM
    Last Post: 03-27-2012, 05:20 AM
  4. Float RL vs Reba RLT (Dual Air or UTurn Air) vs Recon Race/Gold RL
    By mmckechnie in forum Shocks and Suspension
    Last Post: 06-21-2011, 12:34 PM
  5. 2010 Recon Race 120 vs 2011 Recon Gold RL 120
    Last Post: 06-17-2011, 02:12 AM
Members who have read this thread: 21
