Turner Stinger/Fox Vanilla Rear- Mtbr.com
    New poster. HELP!
    Finally found a Stinger frame, but the rear shock (Vanilla) is bent. Fox doesn't make them anymore, though they still make a different Vanilla. Anybody know where I can find one that will work on the Stinger?
    Thanks.
    Quote Originally Posted by jbrad
    New poster. HELP!
    Thanks.
    Unless the shock has a very unusual i2i length/travel, you should be able to find a replacement easily. Vanillas sell cheap on ebay.
    It is unique
    The Stinger had a Fox Vanilla "Pull" shock. Basically the shock was made for that bike alone. I wish I could just grab a different Vanilla, but only the "Pull" design will work. Thanks anyway.
    MK_
    MK_ is offline
    carpe mañana
    Reputation: MK_'s Avatar
    Quote Originally Posted by fsrxc
    Stinger uses a pull shock, not a standard Vanilla. K2 razorbacks use the same concept as the Stinger, you can replace it with one of those shocks, at the very least, or call up KHS and ask what shock options are out there.
    _MK
    "The things you get fired for when you’re young are the same things you get Lifetime Achievements for when you’re old."
