Travel increase- Mtbr.com
Results 1 to 6 of 6
Thread: Travel increase
    person
    Reputation: G-VegasMTBiker's Avatar
    Travel increase
    I had read that you can increase the rear wheel travel of your frame. I also have read that if you do this by buying different suspension plates that it changes the leverage ratio on some bikes. I was wondering if it would affect mine. I have an 02 Kona bear. Thanks again
    MK_
    MK_ is offline
    carpe mañana
    Reputation: MK_'s Avatar
    Well, what you say is true of very few frames. This usually applies to either extremely popular mass produced bikes, when a small manufacturer makes some custom parts to tweak the bike in a way a lot of riders would really appreciate. Otherwise, a few select butique brands have this feature engineered into the frames.
    You would need to do quite a bit of research, but possibly linkage plates from another model Kona could work. You could possibly replace the rear shock with one of the same eye2eye but longer stroke. Just make sure your seatstay won't hit the seat tube at full compression.
    It is also not all that cheap to be investing in linkage plates, possibly new shocks, etc. You may just be better off selling the frame and buying a new one with more travel.
    _MK
    "The things you get fired for when you’re young are the same things you get Lifetime Achievements for when you’re old."
    TNC
    TNC is offline
    noMAD man
    Reputation: TNC's Avatar
    Did you post this on the Kona forum? I'd bet some folks there would have some specifics.
    person
    Huh?
    There's a Kona forum? can you post a link?
    Quote Originally Posted by G-VegasMTBiker
    http://forums.mtbr.com/
    scroll down to manufacturer forums
    Can I let go of your hand now princess?
    MattSavage
    Reputation: mattsavage's Avatar
    Sep 2003
    www.betd.co.uk
    "I wrote a hit play! What have you ever done?!"
    Have Ashtray, Will Travel....
