Torque settings for trunnion shock install & loctite/ anti-seize or grease- Mtbr.com
Results 1 to 3 of 3
    Dec 2013
    Hey there, I've removed my rear shock on my Mondraker and this bike arrived with a pathetic manual.
    What is a typical torque setting for the trunnion end of a shock and the lower link on a modern bike? Just specs from any manual on a modern bike will be fine.
    Also for the bolts should I put grease on the threads, short term locktite, or anti-seize?
    Thanks so much.
    Sent from my SM-G892A using Tapatalk
    damned rocks...
    Reputation: Aglo's Avatar
    Dec 2014
    Go here: https://www.mondraker.com/uk/en/spare-parts
    Pick your bike, download the spare parts catalog for your bike, you will find the information you want in there.
    EDIT: different color in the numbers, means different compound to use, check the subtitles.
    Dec 2013
    Thank you!
  1. Anti-seize, loctite, grease ??
    By b12yan88 in forum Wheels and Tires
    Last Post: 06-20-2014, 01:44 PM
  2. Truvativ PF 30 Install. Clean, Lube, Anti Seize ou Loctite? Please Help
    By Extremier in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-26-2013, 06:36 PM
  3. Replies: 3
    Last Post: 11-27-2012, 02:32 AM
  4. To grease, anti-seize or loctite? (BB)
    By Locoman in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-10-2004, 04:52 PM
  5. To grease, anti-seize or loctite?
    By Locoman in forum General Discussion
    Last Post: 03-10-2004, 10:00 AM
Members who have read this thread: 14
