TALAS RLC STILL leaking oil, and it's not the crush washer!- Mtbr.com
Results 1 to 2 of 2
    New question here. TALAS RLC STILL leaking oil, and it's not the crush washer!
    A few weeks ago, I posted for advice on how to stop a leak on a TALAS RLC out of the bottom of the right leg of the fork, at the threshold adjuster knob. I thought it was the crush washer, but after 5 new ones, it still leaks. I pulled the knob off and let the bike sit overnight, and oil is definitely not coming out of the washer interface. It is coming out of the seal between the threaded end of the damper assembly and the lockout threshold shaft. Does anyone know if this is fixable, or will I need a new damper assembly and a major fork overhaul? Would this be covered under warranty? Any other advice? Thanks!
    Reputation: mtbkr_cookie's Avatar
    I'm having the same problem with my 100rlt. Mine is leaking out of the threshold adjuster.
    have you found out anymore about the problem?
