swinger 3-way SPV - no damping after oil change- Mtbr.com
Results 1 to 19 of 19
    I finally serviced the shock (2005 model) and changed the oil - many, many miles too late. It had no leaks and was working OK before but getting rough, so Iextended some TLC. However, all is not well.......
    I've re-assembled it 3 times now, very carefully bleeding and setting the volumes. All appears good - SPV valve is moving as far as I can tell, and no gurgling or hissing sounds as I cycle the shock so no air in the damper I think. However, I have absolutely no damping. Definitely no rebound on any setting and I don't think there is any compression either. I've tried the SPV from 50-150 psi and it makes no difference.
    Anyone have any ideas as to what might have gone wrong? All I can think is the piston being fully open somehow, maybe a bent shim or stuck rebound valve - but I cannot see anything obvious.
    Any good diagnostic test suggestions?
    All help much appreciated
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by geoffpw View Post
    No, but one option is to send it to Avalanche and have it converted to SSV instead of SPV, lots of happy people after this mod, and it would "rebuild" your shock:
    5th Element / Swinger Speed Sensitive Conversion
    Reputation: Dougal's Avatar
    Did you put the SPV valve in upside down?
    It's an easy thing to do and results in no damping at any pressure.
    Owner of www.shockcraft.co.nz, Mech Engineer, Tuner, Manitou, Motorex, Vorsprung EPTC, SKF, Enduro
    www.dougal.co.nz
    May 2010
    Quote Originally Posted by Dougal View Post
    +1 this is the most likely, and an extremely easy mistake to make if not paying close attention.
    fuggansonofahowa
    Reputation: Hawseman's Avatar
    Quote Originally Posted by scar4me View Post
    +2
    been there.
    I wondered about that, so i double checked. However, ambiguity rules supreme. So: flat side facing away from the piston , right?
    [edit]- I just realized you guys are talking about the pneumatic spring SPV valve in the stack, right? I was referring to the floating piston with my question. Still would like to validate which way up the floating piston goes: flat side towards the eyelet?
    Back to the actual SPV valve: Is it common for the SPV valve to lose it's air? Would that create the same symptom of no damping at all
    Thanks in advance
    bumpty bump - can any of you fine Manitou experts out there answer these questions, please? Cheers, G
    May 2010
    https://www.manitoumtb.com/assets/Se...e%20Manual.pdf
    Page 11, section 6.
    Shows the SPV valve the right way round.
    Yes, the same symptom would also show as no damping if you had sticky seals on the SPV valve jamming its movement.
    As the manual says make sure its greased and returns on its own smoothly before fitting.
    Thanks in advance
    Sounds like you've got it now about the SPV. When the SPV valve loses it's air it tends to stay closed and moves with a knock instead of smoothly.
    They do lose air over time, just like the Fox boost valve (which is the same thing), the cure is to pop them apart, clean and regrease. This gives you another few years.
    Floating piston has the recess towards the oil.
    www.dougal.co.nz
    Awesome! Thanks, Dougal
    Just a flesh wound
    Reputation: Prophet Julio's Avatar
    I have a couple of 3way Air SPV's lurking in my parts bin. It was a brilliant solution to pedal bob but now it is primitive technology compared to the new..stuff.
    My name is Chris and I ride a Ripmo now.
    It's been a while since I messed with spv but I am thinking your spv piston seal is not holding. The lack of rebound is usually a 100% sign that it is not holding and allowing oil under pressure to seep into the air gap not allowing the valve to shut and close off the compression ports.
    I would second the other poster and take this opportunity to send it to Avalanche and get a more reliable and better functioning true piston and stack setup.
    Quote Originally Posted by Jesse Hill View Post
    Honestly, for a 3way it's not worth it as they can quickly and easily fit a more modern shock like the McLeod for a good price.
    If you had a 6way swinger on a period frame it would be worth it. I've done that conversion myself with great results.
    www.dougal.co.nz
    But wouldn't a custom tuned Avalanche function better than a base tuned mcloed? Once Avalanche changes it then it's an entirely different shock.
    All good suggestions.
    I was tempted with avalanche for my main/race bike, but went for a mcleod instead (thanks to Dougal's suggestion on another thread for kicking that off). This swinger is on my spare bike - a 18 year old single pivot K2 4000 (so benefits from the platform). It's still a fun bike to ride even after all these years so I hold onto it, but it gets used a handfull of times a year and it's not getting a $200 avalanche tune! I will tear down the swinger again this weekend and sort out the spv valve and - hopefully - have a bike again instead of a pogo stick!
    A custom tuned swinger 3 way has no compression adjustment. It becomes an expensive single tune shock.
    When as an SPV shock it actually has some compression adjustment. While SPV isn't a good damper, it's still good enough for the application, it is easily tuned to the rider and bike and it's already paid for.
    www.dougal.co.nz
    Low oil level?
    I may be in a similar situation geoffpw, I hope it's ok jump in here
    I just picked up a 2004 Specialized Enduro Pro from Craigslist and it had this shock on it(Swinger 3-way SPV). Im debating if I should spend any effort on oil change/rebuilding or get another shock. I just came back from the garage to research one thing I noticed when I took it off the bike. I released all the air and tried different settings on the dampening and it's working but only the first 10-15 mm from bottom out position, after that it just pop out to fully extended like no oil dampening the movement. My assumption is that the oil level is low. If so, Is it worth to just do an oil change and give that a try or should I just give up on the shock and look for something else. I spent $600 on the bike and I don't really want to end up spending too much more. The forks seams ok and I plan to do an oil change on them as soon as I get the oil.
    Thanks for any reply,
    Regards,
    Emil
    Regarding my own Swinger, I disassembled the damper piston and, sure enough, the SPV valve was full of oil. Cleaned it out and reassembled with some silicone grease and now the shock works good as new. I'll prolly replace the seals at some point, but it's good for now.
    Emil: Definitely do the oil change / clean up service. It's not that hard, and the seals are prolly OK. Download the service manual from Manitou's site. Making the soft jaws is the hard part. I needed a really tight grip to undo mine. Used the hardwood block, 10mm drill approach and the secret was to line the jaws with leather - inside facing the shaft - to get enough friction. Old inner tube works for removing the air can. It is a bit messy - as it's hard to do the bleed with oil going everywhere.
    Thanks for your input @geoffpw
    It was pretty easy to get the air canister off but the control eyelet was a little harder but with the shaft clamped HARD with some wood I got it off. For sure the oil level was low. I removed the remaining oil (I did not disassembly the valve assembly at this point, I just wanted to know if an oil change would do anything) and topped off with some motocross fork oil 5wt and yes, it was a big difference. I need to turn some new eyelet bushings on my lathe before I get to try it on the bike. I have some shock oil coming in so I'll take it apart again and replace with the right oil.
    Another great source with pictures for the rebuilt Henrique Perry's Library | Photobucket
    Regards,
    Emil
  1. Les 29 Swinger Kits
    By seandm in forum Pivot Cycles
    Last Post: 08-02-2014, 08:45 PM
  2. 6.6 with Manitou x4 swinger?
    By deesta in forum Intense
    Last Post: 11-10-2012, 04:17 AM
  3. swinger stroke
    By jo30 in forum Trek
    Last Post: 03-30-2012, 05:49 PM
  4. Fox 36 TALUS no damping after oil change
    By Skooks in forum Shocks and Suspension
    Last Post: 11-22-2011, 11:59 PM
  5. swinger 4 way
    By brankulo in forum Shocks and Suspension
    Last Post: 04-25-2011, 01:57 PM
