Suntour Auron trouble after travel adjustment- Mtbr.com
Results 1 to 10 of 10
    Aug 2017
    I have a 2018 Auron after adjusting the travel to 160, itís been acting up loosing air pressure , dust seal coming off(air side) and the fork itself is some way pulling in itís self so it sits deep in the travel , kinda hard to explain but seems like the air piston is pulling on the lowers.. also when I adjusted the travel all I did was remove two travel reducers .. help! What should I check for thanks.
    Short-Change-Hero
    Reputation: gregnash's Avatar
    Don't know that the 2018MY forks were compatible with 160mm travel, only upto 150mm. SO that could be part of the problem. Also, may be time for new seals/wipers depending on the mileage you have on it. Is this a PCS RC2 version or the LO-RC?
    Go to SR Suntour's website and use the chat function (https://www.srsuntour.us/) and talk with their people. They were always great help when I needed answers or whatnot plus you have access to their shop for parts right there.
    Aug 2017
    I believe itís the pcs. Newest version they have out.. theyíre 130-160 ... the problem is the spring wasnít altered all I did was remove the travel reducers which is pretty much straight fwd stuff.. and the fork has about 8 months of use more like 5 because It wasnít used much during the winter
    Dec 2015
    change air piston u-seal to thick oring. The same problem with all suntour forks.
    N-K
    N-K is offline
    Reputation: N-K's Avatar
    Feb 2016
    I've had something similar happen with my Auron 35. Air gets to the lowers and the fork gets sucked in. I have to try that o-ring as well.
    I never had this problem with my old auron 34.
    Otherwise it has been a great fork.
    Aug 2017
    I contacted suntour and they said the air piston needs to be replaced, Iíll be sending it in for a full service
    Aug 2017
    Quote Originally Posted by nikon255 View Post
    Is their a specific size o-ring to use ? And does the piston need to be replaced?
    Short-Change-Hero
    Quote Originally Posted by Bassballer150 View Post
    Awesome! Hopefully it will be a quick turn around for you.
    Dec 2015
    Piston is made from ptfu and doesnt need to be changed. Just oring. I know only size for epicon. If you have caliper its easy to measure. I guess 5mm thick and smaller ID, than piston groove OD. If they change it again for u-seal it will leak again.
    Aug 2017
    I ended up ordering a new piston and doing it myself, I checked the pressure this morning and itís holding up, I guess the real test will be this weekend when I take it for a ride
  1. Fork Tuning Information needed... SR Suntour Auron LO RC MY16
    By gregnash in forum Shocks and Suspension
    Last Post: 09-19-2017, 09:27 AM
  2. SR Suntour Auron
    By SRvancouver13 in forum 27.5
    Last Post: 02-23-2015, 01:18 PM
  3. SR Suntour Auron travel mod
    By cernymuz in forum Shocks and Suspension
    Last Post: 07-13-2014, 03:35 AM
  4. SR Suntour Rux and Auron
    By SRvancouver13 in forum Downhill - Freeride
    Last Post: 06-23-2014, 10:58 AM
  5. SR Suntour Rux and Auron
    By SRvancouver13 in forum Shocks and Suspension
    Last Post: 12-18-2013, 02:27 PM
Members who have read this thread: 31
