Substitute for Fox 10wt Green?- Mtbr.com
Results 1 to 9 of 9
    KulAdventures
    Reputation: alexk243's Avatar
    Trying to rebuild my 2008ish Fox float 140mm RL fork and it calls for fox 10wt green fluid, but it appears that was discontinued. What are people using as a substitute?
    Yeti 575
    Rocky Mountain Flatline Pro
    My website/blog with project info
    WPL 10wt
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    For oil bath or damper fluid? For oil bath, you can use just about anything, like 0W30 motoroil.
    KulAdventures
    I think the fork is an open bath style, but Fox calls for Fox green 10wt on both sides.
    Yeti 575
    Quote Originally Posted by alexk243 View Post
    I was only referring to semi-bath design, more recent fox forks with closed cartridges. If its full-open bath, then you need actual damping fluid for sure.
    KulAdventures
    Right, So what would work in the place of Fox Green 10wt?
    Would any of these work:
    Fox Red 10wt - https://amzn.to/30MFCpt
    Maxima 10wt - https://amzn.to/2AJRqhR
    BelRay 10wt - https://amzn.to/31RaBSD
    Yeti 575
    Find out the CST of the fox fluid and then check a CST chart, like PVD designs. Thatís how find equivalent fluid weights.
    Reputation: Lone Rager's Avatar
    Dec 2013
    I believe the following chart indicates 10W Red.
    https://www.ridefox.com/fox17/help.php?m=bike&id=530
    Do the math.
    Reputation: Dougal's Avatar
    Here's the interesting part. Your fork never came with 10wt oil inside. It had a 7wt oil which is actually 32 cSt. 10wt is a lot thicker and will slow the fork a lot. Especially in the cold and over sharper bumps.
    We use Motorex 7.5wt (35 cSt) and it works great. It is a lot more slippery than the original oils.
    I have no idea why Fox were recommending 10wt (47 cSt) oils as retrofit for their forks and shocks because they never used those oils themselves. I have measured the viscosity of oils from dozens of Fox forks and shocks over the years and have never found 10wt from the factory.
    They are still using 32 cSt oil (aka 7wt).
    Owner of www.shockcraft.co.nz, Mech Engineer, Tuner, Manitou, Motorex, Vorsprung EPTC, SKF, Enduro
    www.dougal.co.nz
  1. fox green 10wt, looking for substitute
    By desertrat423 in forum Shocks and Suspension
    Last Post: 09-10-2016, 08:59 AM
  2. What's a good substitute oil for Fox Green 10wt?
    By shwndh in forum Shocks and Suspension
    Last Post: 04-16-2015, 11:46 AM
  3. Fox Evolution Float CTD Fork oil -- 20wt gold or 10wt green?
    By volyblmn in forum Shocks and Suspension
    Last Post: 02-15-2015, 10:18 PM
  4. Any shops in SF South Bay with Fox 10wt Green fork oil?
    By gddyap in forum California - Norcal
    Last Post: 04-24-2014, 10:17 AM
  5. Fox 40 - Green and Red 10wt oil
    By pipes10 in forum Shocks and Suspension
    Last Post: 09-20-2011, 06:34 PM
Members who have read this thread: 36
