Stripped disc brake post on Manitou- Mtbr.com
Results 1 to 9 of 9
    Pocket Pool Savant
    Reputation: mcseforsale's Avatar
    Upset Stripped disc brake post on Manitou
    My beloved '01 Six Deluxe has a stripped disc brake post. I'm not sure if I did it, or if it came that way, but when I first installed my brakes, it seemed to strip with relatively light pressure compared to the other post.
    I DON"T want to get rid of this fork, but I'm concerned with it's safety now. I'm not sure there is enough material there for a helicoil...does anyone have any other ideas? Epoxy, JBWeld?
    AJ
    "Stop smirking. It's irritating" - Judge Judy
    not so super...
    Reputation: SSINGA's Avatar
    Pocket Pool Savant
    Yeah, I'ma gonna watch that.
    I've already been watching that one. I also found this:
    http://www.permatex.com/products/pro...&item_no=81668
    128Ft/lbs should suffice!
    AJ
    I need a new name
    The same thing happened to my Manitou Black fork. We drilled the hole out and installed a helicoil. It works fine and isn't unsafe at all.
    Ole
    Ole is offline
    Longer bolt
    Quote Originally Posted by mcseforsale
    AJ
    Try a longer bolt. The post is threaded pretty deeply, and a longer bolt has saved two of my forks. Since the loads are onto the post and not the bolt, you don't have to worry about the safety of doing this.
    Ole.
    MK_
    MK_ is offline
    carpe mañana
    Reputation: MK_'s Avatar
    I second the helicoil. It is a very good solution and a cheap one.
    _MK
    "The things you get fired for when you’re young are the same things you get Lifetime Achievements for when you’re old."
    Reputation: itsdoable's Avatar
    We have helicoil-ed Manitous without any problems. Stripping threads is probably the "only" downside of post mounts.
    telemarc
    Jan 2005
    Where did you get the right size HeliCoil from.I looked all over where I live and had no luck. Can I order some from somewhere?
    otb club member
    Reputation: Chris2fur's Avatar
    Quote Originally Posted by Ole
    Ole.
    Yep. In fact, it's usually the reason they strip in the first place (too short of a bolt putting to much stress on too few threads).
