Star nut sizing / fitting for Bluto- Mtbr.com
    Sep 2019
    Picked up a lightly used Bluto today, but need to fit a star nut in it (seller said he removed it to use in his other fork - mentioned a hex fitting - I didn't think there were removable versions?).
    ID of the steerer tube is 24mm - I presume OD is 1-1/8". Would a typical star nut spec'd for 1-1/8 steerer tubes work ok? Any issues with off brand (inexpensive) star nuts?
    I'll probably grab a setter tool 'cause I may incrementally play with the tube height, so I may be installing / pushing down the star nut - any budget-friendly recommendations?
    Any other advice is appreciated if the install isn't all that straightforward.
    Quote Originally Posted by salinity View Post
    A star nut is a star nut. Any will be fine.
    Secondly, he probably had a bung, something like a hope aheadset expander. Which you can remove and reuse.
    Sep 2019
    Quote Originally Posted by kerpoise View Post
    Thanks for the info. That hope system looks intriguing for the possible multiple cuts, but after a bit of reading it seems they're not all that reliable. Not sure how'd they'd perform on a fatbike with all that weight on the front.
    The star nut is only used to compress the headset bearings. Once you have them preloaded, the stem bolts hold the fork in place, so you can slacken off the headset bolt if you wanted. You could even remove it entirely.
    Sent from my SHT-W09 using Tapatalk
  1. How do you remove a star nut successfully from a steerer tube?
    By sasquatch rides a SS in forum Tooltime
    Last Post: 2 Weeks Ago, 06:21 PM
  2. Need Fat bike advise Bluto or no Bluto
    By brianbmw in forum Fat bikes
    Last Post: 07-12-2016, 03:23 PM
  3. Do new forks come with star nut??
    By EvanSpikes in forum Shocks and Suspension
    Last Post: 01-08-2011, 10:10 AM
  4. Star nut fitting
    By Markleo in forum Beginner's Corner
    Last Post: 10-15-2007, 06:23 PM
  5. What Happened to Me Nut? (Main Pivot Nut)
    By Havefaith in forum Cannondale
    Last Post: 05-08-2007, 04:38 PM
Members who have read this thread: 19
