Someone help me replace my crapy sr suntour fork
I ride a specialized p1 am disc which I am upgrading everything on I ride mostly xc with a little all mountain with some 2 to3 foot drops I am almost 200 pounds and my fork can't handle it it is now starting to creek and makes wierd noises I can spend up to 600 and want something kinda light that can take alot of abuse
Would a Reba be ok and do I need to go with something with a 20 mm hub
No one can suggest anything
There is an RS Recon that has almost the same amount of travel as your fork.
I'd recommend a Pike U-turn. It's light for 20mm and can handle the abuse you described. You can dial down the travel to get the head angle you like.
- You may not post replies
- You may not edit your posts
Forum Rules
