• 06-19-2009
    rickymitchamash
    Someone help me replace my crapy sr suntour fork
    I ride a specialized p1 am disc which I am upgrading everything on I ride mostly xc with a little all mountain with some 2 to3 foot drops I am almost 200 pounds and my fork can't handle it it is now starting to creek and makes wierd noises I can spend up to 600 and want something kinda light that can take alot of abuse
  • 06-19-2009
    rickymitchamash
    Would a Reba be ok and do I need to go with something with a 20 mm hub
  • 06-20-2009
    rickymitchamash
    No one can suggest anything
  • 06-20-2009
    agabriel
    There is an RS Recon that has almost the same amount of travel as your fork.
  • 06-21-2009
    beefmagic
    I'd recommend a Pike U-turn. It's light for 20mm and can handle the abuse you described. You can dial down the travel to get the head angle you like.
