SID XC air pressure question.- Mtbr.com
    Long time no post...I must have lost my old UN/PW...Oh well...
    Anyhow...My 2000 Mt. Tam has a SID XC fork. What is the recommended air pressure range for this fork?
    I can't seem to find any info at the RS site on a fork this old, so any tips on routine maintenance would be helpful as well. It doesn't seem to be leaky either oil or air-wise. How do I go about replacing the oil though, I'm sure it's due?
    Thanks,
    -Kev
    otb club member
    Reputation: Chris2fur's Avatar
    From old "All Tuning Tips:"
    Quote Originally Posted by ButtGumbo
    Thanks,
    -Kev
    <120 lb rider weight= 30-40 PSI
    120-140 lb rider= 40-50 PSI
    140-160 lb rider= 50-60 PSI
    160-180 lb rider= 55-65 PSI
    >180 lb rider weight= 65-75 PSI
    Also, for oil change, check out: http://www.enduroforkseals.com/id8.html
    -Chris
    Quote Originally Posted by Chris2fur
    -Chris
    Thanks Chris...I searched and couldn't find those figures here. Thats exactly what I needed...except it doesn't go up to "fat ass"
    Fat ass here at 225 pounds with a 2000 Sid XC. I ended up with 65 psi, so play around a little as the fork firms up very fast from 65-70psi. Don't know about routine service, but when my fork started to leak, the LBS sent it to rockshox who rebuilt the whole thing, tuned it, and updated all the seals and valves (2001 schrader valve now) for the whopping sum of $40.
    Riding slowly since 1977.
  1. 2001 sid sl negative air pressure?
    By switchblade in forum Shocks and Suspension
    Last Post: 05-03-2004, 10:35 AM
  2. Negative gulp air pressure in 5th Element Air
    By MCF in forum Shocks and Suspension
    Last Post: 05-03-2004, 09:38 AM
  3. 2001 SID XC Setup
    By Brihombre in forum Shocks and Suspension
    Last Post: 03-22-2004, 10:05 PM
  4. Air Pressure on 02 MXR Coil
    By DHinFool in forum Shocks and Suspension
    Last Post: 03-20-2004, 08:23 PM
  5. SPV air pressure versus personal weight
    By slow rider in forum Shocks and Suspension
    Last Post: 03-04-2004, 02:38 PM
