Shortest axle-to-crown at 100mm of travel -- Fox, Reba, MX series?- Mtbr.com
Results 1 to 5 of 5
    Was hoping someone had the axle-to-crown lengths for the Fox Vanilla and the Rockshox Reba at 100mm of travel. I know the newest Marzocchi MXs are longer than they used to be, so they are probably longer than both the Fox and the Rockshox. Also, is the Pike any longer than the Reb for a given travel amount?
    Thanks.
    well, I found what I needed, but can't find how to delete the post.
    Aug 2005
    Quote Originally Posted by futonrvltnst
    Why dont you post the information it might do me some good... oops i meat it might do someone some good.
    jaja
    Lesson of the month: Don`t run of a cliff on your Mountain Bike. It`s quite painful.
    If you can post those result it would help me !
    Vanilla 100mm and 130mm (Realy interested !"!!!!)
    MK_
    MK_ is offline
    carpe mañana
    Reputation: MK_'s Avatar
    Quote Originally Posted by Megaclocker
    Vanilla at 130mm is exactly 500mm, at 100 it is exactly 30mm less. All three of these forks are essentially identical AC within 3 or so millimeters.
    _MK
    "The things you get fired for when you’re young are the same things you get Lifetime Achievements for when you’re old."
