SHIVER Spring Question- Mtbr.com
    I recently replaced the stock springs in my '02 Shiver with a set of heavy ones. I am finding the ride a bit harsh in the front now. My question is, is it ok to mix and match the springs in the fork legs? Can I run one heavy and one medium?
    John
    Jul 2003
    Yes you can, not a problem....
    it is a viable tuning option that has been in use for quite some time. I used to have a old Zocch Z3 dual coil that I ran one Xheavy and one Heavy spring it to get it just right. Two X's were too stiff and two Heavies were too light. The Xheavy/Heavy combo was perfect. You should have 0 problems runing the heavy/medium combo. It is NOT recommended that you run any more than a one rate difference between sides though. In other words an Xheavy/medium or a heavy/light would not be a good thing. No worries though, what you want to try is perfectly fine. It is a nice thing to know too, as it doubles your tuning options for dual coil forks. So have at it. Hopefully it'll dial you in.
    Good Dirt
    Thanks Squash. I semed to remember it being done by guys before, but better to ask and be sure before you try it.
    John
    Jul 2003
    I agree with you John....
    always better to ask if you are not sure, than to go ahead and then end up buggering something up.
    Glad I could help.
    Good Dirt
