Sherman breakout TI coil ? and TPC+?
Can any one tell me if there is a TI coil available for a 150mm sherman breakout and if so how much weight does it save?
Also could i fit TPC+ to the sherman rather than the standard TPC?
Thanks |!!
You can fit a tpc+ in there. The cartridges are very similiar. You'll probably have to call Manitou to get details and then order it through your local bike shop.
Don't know about the 150mm ti coil. but I can tell you that I've swapped 130mm ti and steel coils on my firefly and I couldn't tell the difference in weight. wouldn't be worth the money, IMO. I would spend the $ on lighter tires or rims if you're trying to save weight.
- You may not post replies
- You may not edit your posts
Forum Rules
