RS-1 damper side 120mm, air spring side 100mm- Mtbr.com
Results 1 to 2 of 2
    Aug 2010
    I got my 100mm RS-1 back from a service appointment and noticed that the damper side extends to 120mm while the air-spring side extends to 100mm. I can compress the damper side 20mm to get the wheel on, but I don't remember having to do this in the past. Can anyone confirm that it is normal for the RS-1 to have a longer damper than air spring?
    It seems like its torsional stiffness is worse than usual and I'm working to rule out any possible causes.
    Thanks in advance,
    Marc
    Reputation: trailbildr's Avatar
    Dec 2004
    Normal. Damper is not position-sensitive. Dampers don't top-out anymore to help them function properly. Air spring determines travel.
    mk
    TrailWerks Cyclery
    TrailWerks Suspension Service
    trailwerkssuspension.com
    trailwerkscyclery.com
  1. 2015 Fox fork air spring vs older style air spring
    By Christopher Robin in forum Shocks and Suspension
    Last Post: 12-17-2015, 10:22 AM
  2. FOX CTD 2015 weird spring noise on damper side.
    By Aglo in forum Shocks and Suspension
    Last Post: 06-03-2015, 09:45 PM
  3. RCT3 damper in a dual air Reba 120mm (2009)?
    By Ktom300 in forum Shocks and Suspension
    Last Post: 05-10-2015, 08:00 AM
  4. Got 100mm 29" HT what next 100mm 120mm or 140mm FS?
    By cloudbuster in forum General Discussion
    Last Post: 08-24-2013, 04:23 AM
  5. Fox Float RLC Oil Change Damper-Side/Spring-Side Oil Bath Help?
    By zbear in forum Shocks and Suspension
    Last Post: 09-18-2011, 07:06 PM
