rp23 bottom bush removal and using shock without bush- Mtbr.com
    Just got an rp23 for my giant trance x, the issue i have is that the stock shock dosnt have the lower bush in it, where as this new one does, so do i just remove the lower bush and use it like that or do i need to try and find a different bolt?
    fyi- without the bush in it, it will be the correct size. may sound like a simple answer to make but id like a bit of reassurance.
    Do you have a picture of the original shock?
    AFAIK it should have the lower bushing, so does it have an Enduro needle bearing kit instead? Or maybe the new Fox plastic bushing?
    No bushing in bottom of shock. The bolt is the correct size.
    thanks, just the fiddly bit of removing the bush now, socket,nut and bolt contraption coming up soon.
