Romic coil need lighter weight. fit different length?- Mtbr.com
Results 1 to 6 of 6
    Fake it 'til you make it
    Reputation: JLantz's Avatar
    Feb 2005
    New question here. Romic coil need lighter weight. fit different length?
    The Romic on my new bike is 550lb 2.0", but I can't get enough sag with the coil barely preloaded. The 550lb is the lightest 2.0" Romic I can find. The 2.25" coils come in many different weights. Can I use the longer spring?
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    500lbs x 2.25 is the next spring
    Quote Originally Posted by JLantz
    As long as the springs travel is longer then the shocks stroke your fine..
    Reputation: Davide's Avatar
    450
    If you are intrested I have a 450lb 2.0" in steel or titanium
    Feb 2005
    Great. Ok, so if I can only acheive 8% sag with a 550lb coil, how do I determine what lower weight to get if I want 20-30% for xc? Is there a calculator for this, or is it trial and error?
    Davide- I'm interested in your offer, how much are you asking?
    private: [email protected]
    jrm
    jrm is offline
    And
    Quote Originally Posted by Davide
    I have a 500 x 2.25 i cant use. If interested PM me..
    Feb 2005
    Confirimed by Brian at Romic, it is OK to use the 2.25 spring.
