RockShox RCT3 Low Compression Knob Stuck- Mtbr.com
Results 1 to 3 of 3
    Oct 2012
    Just got a 2013 RockShox SID RCT3, and the low compression knob (silver knob on top of the blue knob) is stuck. It's supposed to turn 12 clicks but doesn't.
    Any ideas on what's causing this?
    Thanks in advance.
    Reputation: two-one's Avatar
    My guess is you turned it too far in one direction, and the thread is now wedged... you can probably turn it loose again, but first feel the fork (with low air pressure, and threshold set to open) to feel whether it's currently closed or open, so you won't make it worse.
    Oct 2012
    Thanks for the reply. With the Solo air pressure down and the threshold set to open. What am I feeling for and how should this be tested?
  1. 2012 RockShox SID RCT3 Compression Not Functioning Properly
    By kris12ax7 in forum Shocks and Suspension
    Last Post: 12-12-2012, 08:01 PM
  2. Stuck low speed compression knob on marz 66 rc2x
    By Metanoia in forum Shocks and Suspension
    Last Post: 09-22-2012, 07:58 AM
  3. totem high speed compression knob stuck
    By btibben in forum Shocks and Suspension
    Last Post: 05-24-2011, 06:04 AM
  4. Reba compression knob stuck
    By ryguy135 in forum 29er Bikes
    Last Post: 03-26-2011, 08:38 PM
  5. Reba Compression knob stuck MOTION CONTROL EXPERTS HELP QUICK!
    By ryguy135 in forum Shocks and Suspension
    Last Post: 03-26-2011, 07:48 AM
