I had recently serviced my Rockshox Monarch RT3 shock - just inspection/clean/oil/grease. However, after installing I noticed it was stuck down halfway. Figured some air got in the negative chamber so removed the air from the valve and then went to remove the aircan. There was a super loud pop when removing this - I hope this hasn't damaged the shock...
I reassembled and pumped up to 200psi in increments. The shock holds air but fully compresses and bottoms out regardless of pressure. The lockout actually works and restricts movement but when it's open it fully compresses.
I disassembled the shock again and found that one of the seals under the aircan had a very small chip in it - would this be enough to cause the above issue?
Put on new air can, added some air can oil, a few drops below the seals, a few more on top. I also greased the air shaft seals with Slickoleum.
Apparently the grease blocked the equalization dimple & caused the stuck down issue I ran into.... OR I added to much air can fluid.
What I think happened is although merely 5-10 drops of oil was used, it caused a hydrolock condition that forced the oil passed the seals permanently deforming the white seals on the piston.
Less oil & grease & new seals solved the issue, but it seams these RS shocks are a little more fragile than their fox counterparts in terms of seals.
And a bad seal can certainly cause a stuck down situation.
83 Ritchey Everest
95 Bianchi Mega Tube ti
2015 Kona Operator Supreme
2015 Kona Process 153
2019 Kona Process 153 CR 29
Thanks, do you mean the white glide rings, had a similar issue myself, also used slickoleum instead of the recommended grease and was being a bit cheap not replacing the seals, so wanted to make sure this was the issue before I replaced them and did a 'proper' air can service.
Yes the white glide rings were the ones that looked smashed when I inspected the shock.
Not sure what the cause was, perhaps to much oil between the upper & lower seals caused it to hydrolock and blew out the lower seals. That's about the only think I would guess, I was running the shock pretty hard just after the new air can & it was leaking oil pretty badly passed the dust seals.
83 Ritchey Everest
Yeah That will probably get you going again. Just go a little light on the oil.
Was thinking about it & too much air can oil might fill the equalization port and eventually transport that oil to the negative chamber & fill it with oil & blow the seals.
Just a guess, but if it can transport air, I'm sure it can do the same with oil.
83 Ritchey Everest
It needed new seals, fresh oil and grease. Now works like new. I'd recommend buying new seals as they seem to stretch and fail after removing them once or twice.
