RockShox Construction- Mtbr.com
Results 1 to 5 of 5
    Just Ride!
    Reputation: kustomz's Avatar
    Anyone know how the stanction tubes are held into the crown on models such as Sid, Duke, Psylo........... pressed, glued, threaded?
    Boom Yow!
    Dec 2004
    Probably pressed and glue in some high tech fashion. I seriously doubt they are threaded.
    CC
    Just Ride!
    I am basically wanting to use the stem and crown from an '02 Duke SL in the construction of a custom built rigid fork.
    Boom Yow!
    Dec 2004
    I would think that they could be removed by heating the juction up (with a torch or something) and be broken free from top down. It would be worth trying if it wasn't a big loss if you screw something up.
    CC
    THE ZOOMING ZOOMER
    The Legs are propably
    are taken down to a really low temp so they will shrink and then press into the crown. When they warm back up to room temp. they expand back to nominal size and have an increased press fit. I would not take a torch to the crown!!! That would change the strength of the aluminum for the worst. I have seen many old style crowns on ebay, the ones that have bolts to secure the legs. You can usually get them for under $10.
  1. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  2. [from Japan] good replacement for a RockShox Mag21
    By potempkin in forum Shocks and Suspension
    Last Post: 07-04-2004, 10:35 AM
  3. 2002 RockShox Judy XC springs?
    By jonowee in forum Shocks and Suspension
    Last Post: 05-18-2004, 03:39 PM
  4. RockShox Recommended Disc Brake Rotor Sizes (xpost brakes)
    By RED5 in forum Downhill - Freeride
    Last Post: 01-30-2004, 07:08 PM
  5. RockShox Recommended Disc Brake Rotor Sizes
    By RED5 in forum Brake Time
    Last Post: 01-29-2004, 11:56 PM
