Rock Shox Reba leak at Gate Adjuster, fixable?- Mtbr.com
    KulAdventures
    Reputation: alexk243's Avatar
    Just rebuilt my 2008ish Rock Shox Reba motion control dual air shock to try and fix a leak near the lockout lever. After replacing all the seals and putting it back together it looks like the oil leak is under the gate adjustment knob. Has anyone else dealt with this? Is it fixable? I couldn't find any information about seals in there.
    Sent from my Pixel XL using Tapatalk
    Yeti 575
    Rocky Mountain Flatline Pro
    My website/blog with project info
    KulAdventures
    It's under this knob above the lock out o-ring. You can hear it bubble when the shock was compressed (no air in air side yet)
    Yeti 575
    Reputation: Polk's Avatar
    Not terribly uncommon, fortunately usually easy to fix.
    You need to remove the damper cartridge, and take off the knobs. Then unscrew the Motion Control spring thing from the top cap. ***The thread is left/reverse!*** Then you can access the seal for the gold knob. Just clean the seal, wipe down all the surfaces in the damper, lightly lube the seal, and assemble everything back together. You will probably find that the compression damping and lockout all work much better afterward, too!
    KulAdventures
    Quote Originally Posted by Polk View Post
    There is no seal to replace there? Just clean it and that will fix the leak?
    Yeti 575
  1. Fixable or Not Fixable?
    By enjoybikes in forum Shocks and Suspension
    Last Post: 04-15-2014, 01:55 AM
  2. Pick one!!! ROCK SHOX DART 3 or FOX TALAS RL or ROCK SHOX SEKTOR???
    By Tattootimmy in forum Shocks and Suspension
    Last Post: 06-18-2013, 01:47 PM
  3. Rock Shox Reba RLT vs Roch Shox Reba RLT Ti
    By zachvii in forum General Discussion
    Last Post: 11-17-2011, 04:14 PM
  4. How to use Rock shox rebound and gate adjust
    By allroy71 in forum Shocks and Suspension
    Last Post: 06-14-2011, 09:38 AM
  5. Rock Shox Domain 302 vs Rock Shox Lyric
    By bome in forum Shocks and Suspension
    Last Post: 05-24-2011, 08:34 AM
Members who have read this thread: 18
