Rock Shox pump doesn't engage on Fox DPS EVOL shock?- Mtbr.com
Results 1 to 8 of 8
    -bustin punks
    Reputation: fatchanceti's Avatar
    Jan 2005
    So I've owned this Rock Shox brand shock pump for 5? years. Works on all my forks (which happen to be Rock Shox) and no problem on my old Fox Triad from my 2011 FSR.
    My new bike has a DPS EVOL rear shock and I can thread the pump on all the way (or what seems like it), but it doesn't engage with the shock.
    Anybody else have this issue? Can I fix it or do I need a Fox or some other brand of pump to interact with this thing?
    Thanks,
    Ryan
    Reputation: Lone Rager's Avatar
    Dec 2013
    IDK about the Rockshox pumps but I've used 4+ different brand pumps (none Rockshox) on Fox and Rockshox shocks and forks interchangeably without issue so I don't think there is a systematic difference. It might be an issue with the pump or the shock. LBS or friends should have some pumps you can try.
    Do the math.
    I had a new bike with a Fox shock that had a small amount of excess material on the schrader valve that would not allow the pump to engage.
    I took a smooth file and gave it a few smooth swipes...and it was fine.(I'm comfortable doing this...but it's not for everyone)
    I have a DT shock that you have to really crank down on the chuck to get it to engage with 2 pumps that I have
    -bustin punks
    Jan 2005
    Quote Originally Posted by the mayor View Post
    Ok, I may give this a try. I grabbed a Fox branded pump at my LBS to try as well.
    Quote Originally Posted by fatchanceti View Post
    I did have a new shock...can't remember what brand...that had it's schrader core screwed way in so the pump would not engage(had to use pliers on the core tool to remove it)
    Unscrewed the core...and put it in finger tight....and it was fine for years.
    Good luck with your problem
    -bustin punks
    Jan 2005
    Fox brand pump engaged fairly easily without bottoming out. Wow - pumping this thing up to 240-250 is quite a workout.
    Oct 2018
    Interesting.
    I aired up my dropper no problem, but still didn't return properly. Deflated, greased it up but then the pump wouldn't engage the valve. Had the shop add air and it worked fine.
    I tested my pump by connecting to fork and it was fine, just didn't like the zero pressure dropper...but it did with the 250 pressure dropper.
    Reputation: bamwa's Avatar
    My monarch just started not filling up.
    Keep trying to do the awesomest thing you've ever done.
  1. Replies: 1
    Last Post: 08-25-2017, 06:11 AM
  2. upgrade fox RP23 to fox factory DPS EVOL rear shock?
    By Picard in forum Shocks and Suspension
    Last Post: 12-26-2016, 08:25 AM
  3. Santa Cruz 5010 on FOX DPS Evol Shock
    By Keithyk in forum Santa Cruz
    Last Post: 03-29-2016, 02:06 AM
  4. Fox Dps Evol kashima Shock firm mode question
    By VERT1 in forum Shocks and Suspension
    Last Post: 02-25-2016, 04:47 PM
  5. 2016 Fox DPS/EVOL Shock for 5010 and Blur TRc
    By buggymancan in forum Santa Cruz
    Last Post: 07-01-2015, 11:42 AM
Members who have read this thread: 41
