Retrofit a Solo Air PIKE with a Dual Position Air Spring- Mtbr.com
Results 1 to 2 of 2
    Reputation: Marmoto's Avatar
    I'm a very happy owner of a Rock Shox PIKE Solo Air 27,5" 160mm fork.
    Thinking in the plan I have for the summer, a TransPyrenees multi-stage ride with lots of long&steep climbs, I'm interested in having the possibility to retrofit my current solo air Pike with a Dual Position Spring... but I'm not sure if this can be done without changing also the CSU (crown+steerer+uppers).
    I did the same thing in my old Dual Air RS Revelation, but now there's an small but key difference: the Solo Air left upper tube has a dimple to allow pressure equalization between + and - air chambers and this is not needed/can interfere in the Dual Position.
    Do you think this retrofit is feasible?
    I am curious as well. I see SRAM has different part numbers for Solo Air vs. Dual Position Air CSU's, so I suspect it wouldn't work for the reason you mentioned, but it would be interesting to hear if anyone had done it.
  1. Pike SO vs Dual Position?
    By myitch in forum All Mountain
    Last Post: 05-23-2015, 12:31 PM
  2. Pike Solo Air vs: Dual Position
    By myitch in forum SRAM
    Last Post: 01-18-2015, 10:47 AM
  3. 2012 Revelation 29 Dual Air ----> Dual Position Air Retrofit
    By hjulier in forum Shocks and Suspension
    Last Post: 07-23-2014, 09:45 AM
  4. Dual Position Air spring in a Solo Air fork
    By Floor Tom in forum Shocks and Suspension
    Last Post: 05-19-2014, 11:28 PM
  5. New Pike RCT3 Dual Position Air
    By HeatmiserSoCal in forum Shocks and Suspension
    Last Post: 08-12-2013, 02:56 PM
