Replacing the suspension linkage- Mtbr.com
Results 1 to 5 of 5
    I have a '16 BMC Speedfox and am getting some creak from the linkage.
    Do you know where I can get replacement parts?
    Also, I assume it's a pretty simple DIY. Is it just unscrew and put back together?
    Reputation: Junersun's Avatar
    Jun 2014
    Quote Originally Posted by bank5 View Post
    If you are going to replace your bearings then def work with Chris at https://www.enduroforkseals.com he has bearing presses too if you want don’t have the right tools for the job.
    Current Bikes
    2015 Transition Patrol AL
    2016 YT Tues AL
    Not entirely that simple but it could be.
    In order to replace bearings in a frame they must be pressed out & new ones pressed back in. Not something you can do with your hands. Ideally you'll need a press or bearing puller to remove, and a proper sized press to put them back in.
    You may just have a dry bearing, in that case you can clean them up with degreaser, let em dry and repack them with grease. I've had pretty good luck doing that. Most of the time the bearings will feel pretty notchy before the cleaning. After regreasing them I'll spin them around a bunch, retop off with grease and they are usually good for another season or more.
    Bearings die a quick death when they are dry and contaminated, a little maintenance can keep them alive quite a bit longer.
    83 Ritchey Everest
    95 Bianchi Mega Tube ti
    2015 Kona Operator Supreme
    2015 Kona Process 153
    2019 Kona Process 153 CR 29
    duplicate
    Thanks for the replies. I watched this video (youtu.be/0nFNX3Smb8g) on it and now have a pretty good feel for things . But I may just take it to my mechanic as there's a couple other things I'd like to worked on as well.
  1. Replacing the linkage bearings
    By mojo_man in forum Ibis
    Last Post: 01-05-2013, 04:11 PM
  2. Linkage suspension software help.
    By DeanFBM in forum Shocks and Suspension
    Last Post: 12-01-2011, 07:00 AM
  3. Replies: 2
    Last Post: 09-24-2011, 05:43 PM
  4. Replies: 8
    Last Post: 04-19-2004, 10:33 PM
Members who have read this thread: 38
