rebuild Revelation vs new Pike- Mtbr.com
View Poll Results: Rebuild or pike?
Voters
7. You may not vote on this poll
  • PIKE PIKE PIKE PIKE
    6 85.71%
  • all about that rebuilt revelation
    1 14.29%
Results 1 to 6 of 6
    May 2015
    New question here. rebuild Revelation vs new Pike
    backstory: I ride a 2014 trek remedy 7 on fairly rough trails, and I've started hitting bigger and bigger jumps.
    I recently blew the seals on my 140mm rockshox revelation fork, and I read in the manual that you can change the travel by replacing the entire solo air spring assembly. I could get 150mm out of the revelation fork...but there's a part of me that just wants to buy a 160mm Pike. The pike would be about $400 more than rebuilding the revelation.
    If I rebuild the revelation will I keep blowing the seals?
    Would buying the pike be worth it?
    What seal failed? You shouldnt have seal failures on a 1 year old fork. A rev rebuild kit is about 20 bucks though, so thats a pretty huge price gap.
    You'd be doing yourself a disservice to not consider a mattoc too! I think you have to ask yourself if you want to be climbing around on a taller fork, it is harder.
    May 2015
    The very top one? on the air side. I'm pretty new to messing around with forks
    The mattoc looks like a great fork, but i ride 29er wheels.
    If I was going to get the pike i'd get a travel adjust fork, because I spend most of the ride climbing.
    Reputation: binrat's Avatar
    May 2005
    I went from a Revelation to a Pike awhile ago. Get the Pike!
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    Pike.
    No brainer.
    Short-Change-Hero
    Reputation: gregnash's Avatar
    If you have the budget then do what you obviously want and get the PIKE. But the Revy is a great fork and with a quick rebuild and new seals (kits are cheap) you should be good. I did the travel adjustment and new oil in mine and literally took me maybe 30-45 minutes and that is with installing the dual air rod backwards and having to take apart and reassemble.
  1. Revelation to Pike.
    By scottalej in forum 29er Components
    Last Post: 12-26-2014, 11:33 AM
  2. Upgrade revelation to pike for 100 eur?
    By rularn in forum 29er Bikes
    Last Post: 09-22-2014, 06:45 AM
  3. Revelation vs Pike on TRc
    By N I C K in forum Santa Cruz
    Last Post: 06-01-2014, 03:00 PM
  4. What do I need to rebuild my Revelation?
    By Alias530 in forum Shocks and Suspension
    Last Post: 01-16-2014, 09:35 PM
  5. Trace/Revelation/F34/Pike
    By kragu in forum 29er Components
    Last Post: 06-02-2013, 05:22 AM
