Rebound too fast or just right ?- Mtbr.com
Results 1 to 11 of 11
    Aug 2017
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Impossible to tell.
    A lot of OEM products force you to run rather fast rebound, because the high speed rebound stacks are too stiff/ineffective. A lot of people unknowingly get "used" to this, but you have to work within the limitations of the suspension, unless you are going to revalve it.
    Jul 2017
    Those handlebars barely moved at all, Iíd say rebound is pretty close to perfect
    You can't test like that. It has to be done on a real trail that you ride.
    Reputation: Lone Rager's Avatar
    Dec 2013
    ^^^ yeah. It looks OK for going down those steps at that speed, but I don't think that's much like the trails you'll be riding. Use that setting and go out and ride a representative trail. Try it again a couple of clicks each way to gauge the effect and then adjust from there.
    Do the math.
    The best at home test is to just bounce around in your backyard, slowing it down until the bucking stops. This is faster, easier, and works about the same as going over steps or a curb over and over.
    But same thing, that gets you a very coarse baseline to get you on a trail and start real adjustments.
    If you were doing nothing but riding stairs all the time, a very fast rebound setting would be appropriate. Probably even just running full open would work! But this does nothing good on the trail.
    Aug 2017
    Thanks for the good feedback guys, Iím going out today in the trails to make real adjustments, was mainly aiming for a base setting and then taking it from there,
    Reputation: R_Pierce's Avatar
    May 2017
    Fork rebound looks fine IMO. I bet its close.
    Aug 2017
    Thanks mate , I took it out on my local trails and felt amazing, quite a big difference from the Reba that was on it
    Dec 2013
    ^^^ That's good. I suggest continuing to experiment with less and more rebound to experience the effect in different conditions. You may find that you'll want different amounts for different riding and conditions.
    Do the math.
    Aug 2017
    Thanks Lone Ranger thatís a good point, I havenít even touched lsc yet but I donít think the fork is diving under breaking so probably wonít have to ?
    I think when Iím at the bike park riding more berms then maybe a few clicks will be needed. ?
  1. Too Much? Too Fast?Too Cheap? Hernia?
    By Duchowski in forum Rider Down, injuries and recovery
    Last Post: 11-12-2017, 06:35 PM
  2. Rebound too fast after fox float air can service
    By dthomp325 in forum Shocks and Suspension
    Last Post: 08-16-2013, 07:21 AM
  3. fox float r noisy on fast rebound but not on slow rebound
    By kneetowaist in forum Shocks and Suspension
    Last Post: 04-29-2012, 10:00 AM
  4. Fox Float R - rebound prob - one click from too fast to too slow
    By TigWorld in forum Shocks and Suspension
    Last Post: 05-05-2011, 03:35 AM
  5. Rebound, Rebound, Freakin Rebound
    By Moo Shoo Pork in forum Shocks and Suspension
    Last Post: 02-09-2005, 09:44 AM
Members who have read this thread: 149
