Reba , rebuilt right- Mtbr.com
Results 1 to 2 of 2
    And He was Not
    Reputation: Enoch's Avatar
    After dealing with the inconsistancy of negative air, and the constant checking of 2 different pressures I switched My Gen 1 Reba over to a Pike coil. I never could get happy with the spring rate on the coil, even with the X Frim spring it seemed to just blow thru the travel or just wallow in the middle. I ended up sending my fork to Suspension Experts in Ashevile http://www.mtbsuspensionexperts.com/HTML/index.html After several detailed conversations with Kevin and Mike they ended up removing the R/S Air spring and installed a custom built Fox Air chamber to go in my Reba. I think I'm finally happy with my Reba. One place to put air in. The pressure stays true from ride to ride. They made the Air chamber nice and large so I could tune the spring curve by adding fork oil. Many thanks to these guys for listen to me and thinking outside the box to come up with a fork that worked for me.
    The Truth is out there. Here it isThe TRUTH
    meh....
    Reputation: Monte's Avatar
    But is it really a Reba anymore?
