Rear Shock Psi- Mtbr.com
Thread: Rear Shock Psi
    Reputation: KAHAIKAPU's Avatar
    Rear Shock Psi
    Hey guys im pretty much new here and i finally got rid of that Costco Shwing and got me an 08 Dawg Deluxe..It has the RP2 on the rear.This is my first air shock,could someone give me advise on how much pressure i should start with? Im about 165 with gear..Thx in advance Aloha Stan
    Bike Crusader~
    Jan 2009
    There should be a rubber o-ring on the shaft of your air shock, you just need enough pressure so that the shock sags around 1/4 of the full stroke....
    You might be able to find more info here too:
    http://www.konaworld.com/owners_area/index.php
    It's a forum for Kona bikes...
    "Ride it, Feel it...."
    Reputation: 4slomo's Avatar
    Here's some info to get you started:
    http://www.konaworld.com/2008_tech_info.pdf
    http://www.foxracingshox.com/fox_tec...008_om_eng.htm
    You might start by pumping it up to your weight in psi (165 psi) and see how much it sags from there.
    What woorks for me is i normally set my sag to 20% both front and rear
