Rattling after installing 04 Z1 FR SL- Mtbr.com
Results 1 to 10 of 10
    Arrrgggghhh!!
    Reputation: BBOC's Avatar
    I just installed my new fork (04 Z1 FR SL onto a Giant AC). This was my first fork install, and everything went smooth. Got it out on the trail and when it gets rough there is a dull rattling noise that seems to be coming from the front of the bike. I can't reproduce the sound at home, and everything seems tight (no play) and is working perfect as far as I can tell. I don't notice any change in performance when I hear the noise either, but it is very annoying. I have not done anything else to the bike between installing the fork and noticing the noise. Any suggestions on what it could be?
    Give 'da people 'da air.
    TNC
    TNC is offline
    noMAD man
    Reputation: TNC's Avatar
    Did you open the fork?
    Quote Originally Posted by BBOC
    Many Marz owners open new forks to check or adjust oil levels. Just asking as a possibility. I have a couple of Z150 SLs, basically just like yours. They are quiet forks--no spring rattle or scrape obviously because of the air spring. I don't know of anything internal on this fork to make that sound barring some strange failure. I'd bet on something being loose or out of whack on the installation--even the best mechanics can boo-boo. It could be internal, but more likely something else. Noises like you're describing can be hard to track down sometimes, as it is quite diffucult to run alongside your bike while going down the trail.
    No, that's not phonetic
    Reputation: tscheezy's Avatar
    Could be a topout "tap". Increase your negative pressure (a lot) and see if it goes away.
    My video techniques can be found in this thread.
    Are you sure your headset is tight?
    qwf
    qwf is offline
    Sep 2004
    Same problem here. Brand new FR SL, still to break in. Huge metallic noise both in compression and in release when the fork is completely without sag, (full extended, for instance if you take a jump or a wheelie). Any suggestion?
    qwf
    qwf is offline
    Sep 2004
    Bumping the thread for help
    Reputation: Saar G7's Avatar
    Jan 2005
    Rattling fork.....
    Funny, 6 months ago I built a 2003 AC1 frame with a Marz FR SL and experianced the same problem.
    I investigated some more and found out it came from the ECC cartridge assembly.
    I sent it back for repair and they could not solve the problem, they replaced the ECC cartridge but it did not help.
    So I took it apart myself and found that the ECC cartridge control rod was slightly loose as the locking ring that held it on the outside was too thin.
    I added a shim underneath the ring and suddenly it was very quite.
    The shim fell after a couple of weeks and I decided to bend the locking ring a bit to give it some "thickness", it is quite ever since.
    A different angle on bikes:
    www.ofanaim.net/has.html
    qwf
    qwf is offline
    Sep 2004
    I eventually shipped the fork back to assistance (I broke the positive camera after 100 hours of light riding). After assistance everything was fine and the fork is plusher and much more enjoyable than before, the ECC now works perfectly.
    Ratling
    Hello i just baught a marzo am sl and i do have this noise every time the fork is coming up after compression, on a french forum they said it is coming from the TST cartridge and if you fasten the rebound the noise will go away i will try that tomorow but i am not relly happy with that.
    WHERE CAN I GET A MANUAL HOW TO DISASEMBLE THE FORK???
    OK i tryed to fasten the rebound and it magically worked no more ratling this 45 km where really good even with just +2CELCIUS it is supose to snow tomorrow
    Aniway when it was ratling i was 3 cliks away from the maximum slow position
    i put it 8 cliks away mid range and during the ride i turned one more now i am 7 cliks and still have no noise
    But what the purpose of having some really slow setings if you can t use them.
    qwf
    qwf is offline
    Sep 2004
    Have you tried on the Marzocchi website? Anyway if it is brand new it should be covered by the warrancy. I'd ship it baack to your national distributor for assistance.
  1. TPC vs. HSCV? '04 Z1 FR qr20 vs sherman flick '04?
    By BudhaGoodha in forum Shocks and Suspension
    Last Post: 12-25-2004, 05:54 PM
  2. help w/ marzocchi z1 fr sl ' 04 fork
    By tia4 in forum Shocks and Suspension
    Last Post: 11-19-2004, 11:09 AM
  3. Marzocchi Z1 FR SL on a 5-Spot
    By blackjack843 in forum Turner
    Last Post: 06-24-2004, 02:46 PM
  4. Marzocchi Marathon SL and Z1 FR SL-same internals: same performance?
    By dawgcatching in forum Shocks and Suspension
    Last Post: 05-25-2004, 02:50 PM
  5. 04 Marzocchi Z1 FR SL
    By duc135 in forum Shocks and Suspension
    Last Post: 03-26-2004, 09:14 AM
