Pushed Talas Fork Seals leaking...what to do??- Mtbr.com
Results 1 to 6 of 6
    Reputation: string's Avatar
    My '03 Talas Fork had the full Push treatment last December and recently started leaking oil on the Talas side stantion every ride. Its not a lot of oil, but its definately there. So far I have not seen a change in the forks performance but assume its comming.
    I'm wondering if it should just keep riding the fork as is (I'm planning on replacing the fork in the next 3-4 months) untill I notice a change in performance or if I should replace the seals now. Since it was done less than a year ago and I'm planning on retiring the fork in the next few months, I don't really want to spend the $$ on another full Push factory rebuild, but I want to keep it in working order none the less.
    I've thought about Enduro seals (or finding some fox seals) but I don't know how hard it is to change the seals on a Talas Fork myself?
    I've email Push hoping they could help, but have not heard back yet.
    Any suggestions?
    Peace & Love
    Reputation: FoShizzle's Avatar
    call them. they get swamped by emails and you will likely be able to reach Jimmy or Darren
    Bodhisattva
    Reputation: The Squeaky Wheel's Avatar
    I wouldn't worry about it.
    The Fox seals are designed to let a little oil through. If the amount of oil appears "excessive" or if you notice any change in performance then get the seals replaced.
    Thats what I was leaning towards doing.
    I'm a little worried I starting to see more oil, but just need to wait and see. I kinda figured as long as there is no change in performance I should be OK.
    Quote Originally Posted by The Squeaky Wheel
    My PUSHed Vanilla got the 05 seals. Now they work so good, the right side squeeks, so I have to put some oil under the lip to keep it from squeeking!
    I'm not sure if I got the '04 or '05 seals but I never had any trouble with the '03's. Other than the Seals the forks performance is great.
  1. Help with Fork: Marzocchi Bomber Drop-Off Comp, 130mm travel
    By noah1711 in forum Shocks and Suspension
    Last Post: 05-11-2013, 05:28 AM
  2. Everything you need to know about the PIKE's Motion Control Damping!
    By MicroHuck in forum Shocks and Suspension
    Last Post: 02-21-2005, 10:25 AM
  3. Replies: 5
    Last Post: 04-14-2004, 08:19 AM
  4. Cannondale Lefty Max+ compared to TALAS :my $.02
    By dawgcatching in forum Shocks and Suspension
    Last Post: 04-13-2004, 10:39 PM
  5. rigid fork question: Alu, steel, carbon...
    By jh_on_the_cape in forum Singlespeed
    Last Post: 03-24-2004, 05:18 PM
