• 07-03-2006
    aye-aye
    Pike air, Pike coil, Z1 light or Z1 SL
    my heckler and i want pluushness and michael bolt-on stiffness.
    ive got an 05 AM1 which is ok but a bit braky-divey.
    the cost difference between all of them isn't much.
    the Z1 light would be a no-brainer if it had TAS travel adjust in UK but it doesnt and i like to run AM1 at about 140mm for HA sweet spot, but the Z1 SL has no ETA which i use a bit for cwmcarn type techy climbs.
    so should i just shut up and get a pike (which?) or put up and get a Z1?
    you decide
    p.s. ive considered other forks but cant do post mount cos my louise FR's are IS only.
  • 07-03-2006
    MK_
    you decide
    Pike @ 140mm of travel a2c = Z1 @ 130mm a2c. If you sweetspot is at 140 with the AM1, then forget about the pike.
    SL will dive more than the Light.
    _MK
  • 07-03-2006
    aye-aye
    yeah i kind of thought the Pike might be a bit short at 520ish a-c.
    i know its not much but i think u can feel the difference.
    i didnt realise the Z1 SL would dive more than the light, any idea why?
  • 07-03-2006
    tscheezy
    I don't think you would find the Z1 light to be that different in ride characteristics from your current AM1. If you wanted to, you could buy the light, pull the TAS out of your AM, and put it in the light, and sell the AM with the light's old ETA cart. You would basically just be back to an AM with 20mm dropouts (which is what I have).
  • 07-03-2006
    SSINGA
    Funny - I was going to suggest the same thing!
  • 07-03-2006
    MK_
    It has to do with the spring. Coil spring is linear, whereas air is non-linear. It has a fairly low spring rage, past the initial point, and it ramps up deep in the stroke. This means that the fork will dive a bit before the spring rate increases enough to support the forward weight shift. The Marzocchi SL system is better than most, in not having a lot of brake dive, plus you can help the behavior with slow speed compression adjustment (or heavier oil).
    In addition, SL is not going to be quite as buttery smooth as the Light, due to additional friction caused by air seals of the doppio system.
    _MK
  • 07-03-2006
    Znarf
    Hi,
    I currently ride an 05 Z1FR1 in my Heckler.
    I think it is a tad high though. Had a Pike SL before and I think IŽll go back to a Pike again.
    The Z1 is too stiff (spring rate) for me(148lbs). I already bought soft springs(available since 4weeks or so for 2006) but they are not soft enough, fiddling with the oil levels was partially succesful.
    When I do a higher drop to flat, travel usage is perfect. No bottoming, but almost all the travel is used.
    But, when riding on a trail or dh with drops with a good landing I just use 110mm MAX of the 150mm the forkŽs got.
    That sucks. Just feels a bit too harsh or too stiff.
    And therefore IŽll go back to a Pike Air uturn or Pike coil uturn with a soft spring.
    I love the Z1 for the look and stiffness(not the stiffness of the coil though;) ) It just looks so cool on the Heckler.
    But the Pikes uturn is also better for my purposes. Long technical climbs or level singletrack is fun with a 120mm full active Pike =)
    Just need to sell the Z1 and buy a Pike.
    Greetings Znarf
  • 07-03-2006
    TNC
    You've gotten good fork advice here, but I was wondering about your caliper mount statement. Are you saying you don't want to have to change your Louise to post mount or that it can't be changed to post mount? One of the guys in the shop here changed his Louise FR from an IS to a post by changing part of the caliper body...at least I don't recall it requiring a whole new caliper...but maybe I'm wrong. Yeah, it's not as easy as just changing adapters like many brake manufacturers use.
    BTW I'd go with swapping out the guts that I wanted out of the AM into the Z1 like Tscheezy and SS suggested...then sell the leftover fork.
  • 07-03-2006
    aye-aye
    cheers for the info on marz air forks mk, coils just seem right to me.
    i can also see that a pike with its lower a-c would be great for singletrack.
    getting Z1 light and installing AM1 TAS would be best of both worlds i think, anyone know if spacers can be fitted to TASless AM1 to drop travel to 130mm / 518 a-c? so that i could put it on my hardtail?
  • 07-03-2006
    aye-aye
    the UK magura importer reckons that i would have to buy a whole new caliper, i've seen IS to post adapters in the magura catalogue to hop up a rotor size but magura guy reckons its for a bigger IS caliper!
    anyhoo i might have to bite the postmount bullet when Lyrik comes out cos that looks pretty good.
  • 07-07-2006
    loco-gringo
    I don't know why you wouldn't just get the Z1 Light. What are the drawbacks? I missed a serious point here somewhere I think.
    edit - I see it doesn't have the TAS in the UK, but I would think you could find it. Why not just put new 20mm lowers on the AM???
