Pike 454 Uturn with Hope pro2. 2 issues- Mtbr.com
Results 1 to 9 of 9
    mjc
    mjc is offline
    I just installed a Pike Uturn with a Hope Pro2. The maxel hub qr seems to stop in the wrong place when the wheel is installed leaving the lever facing strait ahead...
    Also, I have a hayes 8 inch rotor- Even though I move the caliper ALL the way inbord, it still has major rub. On the previous fork-Fox Float RL 130 the caliper lined up right in the center.....
    Any suggestions for correction would be apreciated.
    Quote Originally Posted by mjc
    dissassembe it and rotate the lever 180 and put it back together.
    there is also a link to a pdf about being able to position it at any direction you want.
    i can email it to you if need be.
    as for teh caliper, take it to the lbs, or use spacers or something.
    melon farmer
    Reputation: marcus_dukakis's Avatar
    Apr 2005
    Jun 2005
    pdf link no worky..
    Jun 2005
    Quote Originally Posted by westin
    What he said
    EDR
    Reputation: eatdrinkride's Avatar
    Jun 2005
    I've got 8'' hayes rotor on my pike coil and i'm pretty sure I had to put some shims (errr...washers) on the mounts to get it set up right. I don't have it in front of me...get shims, fool around till you get it right. As far as the Maxel.....what everyone else said. Loosen the nut on the opposite end of the lever until you can flip the lever around 180 degrees, re-tighten.
    You need the qr adapter for hayes brakes, not the 20mm one for the pike.
