Pike 29 160mm debonair in 170mm yari??- Mtbr.com
Results 1 to 2 of 2
    csf
    csf is offline
    Reputation: csf's Avatar
    Installed a rs charger 2.1 RC (00.4020.170.000) in my 18 yari rc 29+ (FS-YARI-RC-B1) 170mm. The fork is specd withe the debonair air spring. The damper rod is 10mm longer than the air spring rod. I noticed the spring rod was stamped pike 29 160mm. Did RS PUT THE WRONG AIR SPRING IN? Will try and call them tomorrow to see if this is a problem. I was told the charger damper was the correct application. Anyone el se seeing this?
    May 2018
    I am not 100% sure, but i heard that pike 29 has lyrik chassis. In this case it could be OK.
  1. Convert OEM 160mm Yari (27.5) to 170mm with a Lyrik air shaft?
    By Frkan in forum Shocks and Suspension
    Last Post: 01-31-2019, 04:16 PM
  2. Yari - Debonair air spring
    By Tourendo in forum Shocks and Suspension
    Last Post: 10-11-2018, 03:55 PM
  3. Pike DebonAir upgrade kit: no max tokens on 160mm/29er configuration?
    By codysoyland in forum Shocks and Suspension
    Last Post: 07-26-2018, 11:42 AM
  4. Pike 29" 160mm and 26" 160mm: same internals?
    By nickz5 in forum Shocks and Suspension
    Last Post: 09-22-2015, 08:01 PM
  5. Monarch Debonair Plus R vs Debonair RT
    By frango in forum Shocks and Suspension
    Last Post: 04-14-2015, 12:25 PM
Members who have read this thread: 12
