Pike 140mm vs Pike 150mm. Bike set up opinions.- Mtbr.com
Results 1 to 2 of 2
    Reputation: biketavioumaximus's Avatar
    Hi All,
    I have recently purchased a Spider 29 Comp. I have it set up with 130mm rear and a Pike 150mm front. I orded a 140mm but a 150mm turned up.
    Is there much difference between them other than the obvious 10mm?
    Is it a simple matter of setting more sag to have a the same A2C of a 140mm?
    Would a 140mm make much difference in bike handling????thanks in advance.
    Reputation: ColinL's Avatar
    Feb 2012
    Use sag to tune how soft the fork is, if you bottom out, and pedaling efficiency. Don't set the sag for a desired ride height / fork length. The air spring rate difference of +/- 10mm is much more significant than either the bike's steering geometry or your weight distribution on the bike.
    Ride it at 150mm. Set the sag and tune the dampening.
    Later, if you want it to steer just a bit quicker, or climb a bit better, you can lower the fork to 140.
  1. 140mm or 150mm Pike fork on my Remedy 7 29er??
    By teethandnails in forum 29er Bikes
    Last Post: 12-08-2015, 12:43 PM
  2. Tallboy LTc 140mm or 150mm Pike, angleset ?
    By M320 in forum Santa Cruz
    Last Post: 03-09-2015, 02:10 PM
  3. Intense Spider Comp with Pike 140mm or 150mm
    By LewisQC in forum 29er Bikes
    Last Post: 05-03-2014, 12:37 PM
  4. 140mm or 150mm Pike to Remedy 29?
    By jaakkoso in forum Trek
    Last Post: 07-31-2013, 02:20 AM
  5. Replies: 8
    Last Post: 05-06-2013, 05:37 PM
