which one? Sid RLT, Sid XX or Fox 32 RLT- Mtbr.com
Results 1 to 3 of 3
    Time to replace my recon xc solo air on the SS.
    faults with the recon; heavy, no lock out or comression adjust, IS mounts for the brake....m975 IS front disk brake.
    currently running a Hope Pro 2 hub 9mm axle.....160mm rotor.....
    Have to get the Hope IS to post mount adaptor to run currenbt brake on a post mount fork....this also means a larger rotor 160mm up to 180mm....I love the m975 brake
    If I go with the Fox or Sid XX I need to convert the hub to 15mm...............
    What's a man to do I love the Sid race on my other bike
    I have Sid Team 100mm on my SS. I have a White Industries hub up front which can convert from 9mm to 15mm maxle, so my next fork will be 15mm. Having said that, I reckon the lockout is really important on a SS, as you're up and hauling alot. I reckon the SID's poplock in combination with the Blackbox Motion Control adjuster is the go.
    Reputation: Joel RW's Avatar
    Quote Originally Posted by mat-with-one-t View Post
    In addition to this rockshox XX forks come with "xloc" simple to use more reliable hydraulic lockout...60grams lighter for lockout weight weenies
