Old fork maintenence- Mtbr.com
Results 1 to 17 of 17
    Sep 2018
    New question here. Old fork maintenence
    I just bought a new unopened 2018 fox 34. Since it has been sitting in a box for a year should I do a lower leg service on it? I am not sure if the oil goes bad.
    Jan 2009
    The oil does not "go bad." The fork is certainly not "old." Just ride it.
    Reputation: Redlands R&C's Avatar
    Dec 2013
    You wouldn't necessarily have to do it, however, it might not be a bad idea. Often times, new forks (whether in box or on new bikes) have less than ideal amounts of lube on the foam rings and a little less oil than they should in the lowers.
    Up to you, if you want piece of mind knowing it is as good as it can be for brand new, drop them and service it up. Otherwise, bolt it on and ride it!
    Silly bike things happening.
    Reputation: Vespasianus's Avatar
    I would. Honestly, many shocks and forks come dry. Easy to do and even easier before installation.
    It is the Right of the People to Alter or to Abolish It.
    Caca pasa
    Nov 2003
    Quote Originally Posted by Vespasianus View Post
    ...even easier before installation.
    Helluva good point.
    "합니다 행사에서 디비 판매 합니다 관련해" Lesleybien
    Hogan Lake blog. A section of Hogan Lake trails here.
    Self Appointed Judge&Jury
    Oct 2000
    Quote Originally Posted by Finch Platte View Post
    Helluva good point.
    Meatbomb
    Reputation: Phillbo's Avatar
    Thanks for the clarification. I was not sure what he meant.....
    Reputation: Lone Rager's Avatar
    Dec 2013
    I would let it go until the first service interval. Oil foam rings by storing the bike hanging from the front wheel or inverting the bike. No harm in checking though, and if you're going to do it, pull the air spring and clean excess grease out of the negative chamber.
    Do the math.
    Caca pasa
    Nov 2003
    Quote Originally Posted by Phillbo View Post
    Yeah, wtf.
    Oct 2000
    Yeah, wtf.
    Lol
    A bored day at work sends the mind wandering. Just watching Finch with his grammar. After all he is one of the grammar cops around here.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    IMO, they almost always (but that doesn't mean always) put the correct amount of oil in there, but for very low-volume oil-bath forks, a significant portion is absorbed by the seals, the foam ring, the bushings, etc., it ends up being pretty skimpy and doing a service is often a good idea. An older fork probably has dried out a bit and will probably absorb even more of the original oil. The air-spring side is a fairly small amount, so if anything, that would be the side to usually service.
    Caca pasa
    Nov 2003
    Lol
    That's right. And don't you forget it!
    (Lol, found this one, too. D'oh!)
    Name:  Hitler grammar.jpg
    It's 'you're,' not 'your.'
    Oct 2000
    Lol
    Alright, OP service the fork prior to installation for peace of mind. Not necessary but a great idea. >bandwagon<
    Hitching a ride
    Reputation: Schulze's Avatar
    Feb 2007
    Also they often pack it with too much Slickoleum and clog up the air transfer port. I would do a lowers service for sure first. I got a 2019 over the summer that had a clogged port.
    Dec 2013
    In my experience, Slick Honey itself is usually not viscous enough to clog a transfer port. The port is pretty small but a few compressions as the air spring is pressurized will clear it out, even when there's way too much Slick Honey in the negative chamber. There may have been a glob of something stickier that clogged the port.
    Do the math.
    Caca pasa
    Nov 2003
    Quote Originally Posted by Lone Rager View Post
    Jism?
    Hitching a ride
    Feb 2007
    Or maybe it became sticky sitting in a warehouse for a year. You could hear it being clogged with compressing the fork to that spot.
    I removed a few fingerfulls of the stuff and re-assembled, fork worked awesome ever since.
  1. Alot of questions, preticulary about maintenence
    By Amit Ifrach in forum Beginner's Corner
    Last Post: 12-13-2014, 10:09 PM
  2. Fox talas rear shock maintenence?
    By ou2mame in forum Shocks and Suspension
    Last Post: 06-23-2014, 01:18 AM
  3. Very Routine Maintenence
    By nrsmd in forum 29er Bikes
    Last Post: 06-08-2014, 04:38 AM
  4. Mt Penn BAMBA Trail Maintenence Sat. Dec 15
    By bbohr in forum Pennsylvania
    Last Post: 12-13-2012, 10:34 AM
  5. Bearing maintenence
    By bubba13 in forum Knolly
    Last Post: 06-24-2011, 09:53 AM
Members who have read this thread: 70
