Old Epic.... Brain Trouble??- Mtbr.com
Results 1 to 5 of 5
    Old Epic.... Brain Trouble??-7dbabd6e-3cb6-489d-94c8-46480ed6718a.jpgWhat year is it? I know that this is a useless question until I figure out how to add pics with my I-phone. For now I'll ask a question about my antique brain shock. I have a old Epic with the brain shock mounted on the rear triangle. The brain is mounted vertically on the shock. The only adjustment on this one is rebound. A friend noticed that I was getting a lot of movement in the suspension when pedaling on the road one day. I decided to get a pump and adjust the sag hoping that would fix the trouble. I think that this setup is supposed to compress the shock 10mm. I needed to add air to get 10mm sag. I overshot the needed pressure a little so I went to let a little air back out. Should I get oil out of the inflation port on my brain shock? What are good sources for info on maintaining my suspension? I'll post pics when I figure out how.
    Jan 2016
    2019
    Quote Originally Posted by areks View Post
    2019
    . Ha ha! What year was the the bike built? Old Epic.... Brain Trouble??-2a4c11f6-62e5-4283-8fc1-267278aadcb2.jpg
    "I've never been better .... nor cared less!"
    Reputation: Lone Rager's Avatar
    Dec 2013
    It's pretty common to get a little oil out of the air valve as there is oil in the air spring to lubricated the seals. This will happen especially if you press the poppet and blast air out suddenly. Shock pumps have bleed valves which provide controlled release of air making it easier to set the desired pressure.
    Of course you may have other problems going on in that shock, like damping oil leaking into the air chamber, worn damper seals, air on the wrong side of the ifp, etc...
    IDK where you could get that shock serviced, but one place I'd ask is Traxxion Dynamics.
    Do the math.
    Thanks LR. I won't worry to much for now. I'm off to ride the local trails now. Hopefully everything will work well. I'm not sure that I will know if the brain is working or not though. I don't have much experience with these.
  1. 2018 Epic Brain vs Old Brain
    By dpastore22 in forum Specialized
    Last Post: 03-13-2019, 07:05 AM
  2. Replies: 0
    Last Post: 05-23-2013, 04:15 PM
  3. 09 epic Brain Vs 05 epic Brain
    By SteveComber in forum Specialized
    Last Post: 03-10-2011, 06:31 PM
  4. diff epic brain 2007 vs epic brain 2008
    By jp_666 in forum Specialized
    Last Post: 07-10-2008, 10:47 AM
Members who have read this thread: 14
