Nitrogen in Forks, What am I Doing Wrong?- Mtbr.com
Results 1 to 13 of 13
    Dec 2011
    Recently, I used my off-road motorcycle nitrogen shock charging equipment to charge my 2009 Gary Fisher Tassajara Rock Shox Tora SL air forks. I weigh about 230 when geared up, so I put 188 psi according to the gauge. When I took it for a test ride, sag was at about 55%. A couple of days later, a friend with a Fox shock pump let me borrow it. The gauge showed 125 psi. I pumped it up to around 190, and they felt great with a normal amount of sag.
    I had the same issue before on a 2012 Trek Cobia (some sort of Solo Air Rock Shox) (gauge showed one thing and sag was way soft). I have done a couple of motorcycle shocks since, and they were fine.
    It is a lossless chuck (Race Tech brand). Any ideas on what I did incorrectly?
    Thank you for any advice on the charging.
    Reputation: two-one's Avatar
    55% sag with 188 psi in a fork? Sounds like the air spring is broken, and the main piston seal is worn or desintegrated
    Dec 2011
    Well, after using a Fox shock hand pump, it was fine.
    Does it have to be cycled through compression some during charging??
    Your gauge is off. Also, total waste to charge an air spring with nitrogen!
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Some shocks have to be cycled to equalize the negative and positive air chambers, if you just pressurize it and go ride, it'll equalize as soon as it sags and then some of your air goes into the negative chamber.
    Reputation: tom tom's Avatar
    Quote Originally Posted by One Pivot View Post
    Why?.......Maybe he has more money than you do? Or is there another reason?
    I Pity The Fool That Can't Ride A Bike Without A Dropper!!
    Quote Originally Posted by tom tom View Post
    Are we financially flexing based on nitrogen purchasing power?
    We dont generate the heat necessary to make wet air matter. For bikes, it's best to use the same shock pump for consistency. You're unlikely to be dragging a nitrogen tank to the trails, but a shock pump easily tosses in a pack for tuning. You might as well start out with the more versatile tool.
    Exactly. When airing up from zero, best to go in reasonable increments, and cycle the fork several times between each "step".
    I use 25 psi increments. I figure this approach really has nothing to lose, and only takes a few extra minutes.
    Whining is not a strategy.
    Dec 2011
    Thank you very much for the replies!
    I will cycle / add / cycle / add next time.
    I don't own a bicycle fork / shock pump. The only way I have to get the PSI that high is to use my off-road motorcycle nitrogen tank or wait and borrow a friend's bicycle pump.
    I put nitrogen in everything! Ifp, air springs, tyres......inflatable mattresses......lungs.....
    Reputation: Lone Rager's Avatar
    Dec 2013
    There can be such a thing as too much nitrogen...
    Do the math.
    Quote Originally Posted by JohnnyC7 View Post
    That's the other reason 80ish percent nitrogen is plenty.
    Reps in da house.
    Reputation: SpecialWarr's Avatar
    https://www.youtube.com/watch?v=DM6_pUE-3Pg
    TOOOOOOOoooooo much nitrogen!!
  1. why don't forks use nitrogen/air charged dampers?
    By dthomp325 in forum Singlespeed
    Last Post: 07-30-2014, 06:09 PM
  2. Forks, Forks, Forks, Forks, Forks, Forks
    By Ben12321 in forum Beginner's Corner
    Last Post: 05-04-2008, 05:01 PM
  3. What am I doing wrong? Incompatible V's/forks?
    By Cloxxki in forum 29er Bikes
    Last Post: 08-15-2006, 11:18 AM
Members who have read this thread: 153
