Newer Fox X2 retaining ring concern- Mtbr.com
    No Clue Crew
    Apr 2005
    Not sure how long this style has been in effect, but I have a new 2020 Fox X2. This shock has a metal C-style retaining ring that holds the air can on the shock body in combination with a slot on the can itself.
    Needed to add some volume spacers and removing the ring the first time was fiddly. Ended up using a couple picks to get it started.
    When reassembling, I noted the ring could now just be slotted into the retaining groove very easily by hand; i.e., it's nowhere near as tight and fitted as it was originally.
    Cause for concern regarding blowing the air can off?
    I did partially air it back up (to ~150 psi) and the can held.
    Probably nothing, but thought I'd ask. Thanks for input.
    Just like a raindrop, I was born to fall.
    Nope it will be fine. The aircan slides back slightly and traps the ring fully in the groove.
    Reputation: Lone Rager's Avatar
    Dec 2013
    ^^^ yeah, the can traps the ring... so...to remove it, I push the can away from the ring and spread the gap with my thumb nails just enough to get it off. Easy peasy.
    Do the math.
    No Clue Crew
    Apr 2005
    Thanks.
  1. Eagle Cassette Retaining Ring Issue
    By Magsrgod in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-07-2019, 10:15 AM
  2. Best Retaining Ring Pliers
    By Pb-2-Au in forum Tooltime
    Last Post: 12-31-2018, 02:03 PM
  3. Monarch plus retaining clip/ring options
    By Dropper in forum Shocks and Suspension
    Last Post: 07-18-2018, 08:15 PM
  4. Replies: 9
    Last Post: 02-05-2016, 07:48 AM
  5. Replies: 17
    Last Post: 09-15-2014, 09:41 AM
Members who have read this thread: 43
