Need Advice: Rockshox XC32 TK 100mm Vs Rockshox SL TORA 100mm- Mtbr.com
Results 1 to 6 of 6
    Oct 2013
    New question here. Need Advice: Rockshox XC32 TK 100mm Vs Rockshox SL TORA 100mm
    Hi,
    NEWBIE QUESTION..
    I am in the process of upgrading the suspension on my Bergamont vitox 7.3. Currently its having a Suntour XCT MLO 100mm Fork. The only two forks available with my LBS right now are the XC32 TK and the SL TORA. I have the following doubts before upgrading:
    1. Which one of the above Rockshox is better?? I mostly do XC, single tracks and easy downhills(no big jumps at all).
    2. What is the difference between the 2 Rockshox models?
    3. I am on the heavier side.(260lb) and 6 ft in height. What PSI should I maintain with respect to the suspension presuming that both the above forks are solo air and need a shock pump??
    Help is much appreciated guys. Thanks in advance. Good day
    Cheers
    Raj
    Reputation: Kiwiplague's Avatar
    Basically they are the same fork. The XC32 is the replacement for the older Tora forks. As far as recommended psi, you will need to add air to the fork until you get approx 20% sag. Actual psi will vary, so just need to experiment really. The forks will have a guide on the back of them, they will give you a good base to start from.
    I don't crash, I just have slightly uncontrolled dismounts!
    Reputation: joe_bloe's Avatar
    Is the XC32 a coil spring fork or air spring? If it's coil spring, you will almost certainly need an extra firm spring kit for it.
    Oct 2013
    ^^^ I am a newbie to the world of suspension. Just know the basics..
    Oct 2013
    Quote Originally Posted by joe_bloe View Post
    @ joe_bloe: I believe it is a solo air suspension. By this term I am Presuming that a combination of air and spring, right??
    Just an air spring, no coil. Solo air systems have a self regulating air based negative spring. All you need to do is fill your fork to the desired psi/sag, and you are set to ride.
  1. 2011 Rockshox Sid RLT Ti 100mm Fork
    By dharel1705 in forum Shocks and Suspension
    Last Post: 08-06-2012, 11:44 AM
  2. 80 -> 100mm conversion 2011 RockShox Tora TK 29 SL
    By n8henrie in forum 29er Components
    Last Post: 03-23-2012, 05:27 PM
  3. 29er 100mm fork: Fox F29 100 vs Rockshox Reba 29 100?
    By LCW in forum Shocks and Suspension
    Last Post: 03-20-2012, 08:46 PM
  4. Can I put a 100mm RockShox on my Trek?
    By rustytrek in forum General Discussion
    Last Post: 03-16-2012, 07:21 PM
  5. Replies: 10
    Last Post: 09-11-2011, 02:40 PM
