Marzocchi Z1FR1 rebuild question- Mtbr.com
    Dec 2004
    Long story cut short, I had to replace the HSCV cartridge on my 2005 Z1's. On reassembly the cartridge spins when torquing up the foot nut, should I use an air gun to try and tighten? Also should I be using loctite on the threads for the footnut as I don't believe there is a lock washer.
    No air gun. No locktite. A little grease on the threads and the o-ring. Put the springs in and top-caps on. Compress the fork, maybe use a tie-down if you've got one to put pressure on the cartridges. Then try it.
    Dec 2004
    thanks for the advice, I'll try it tonight.
    Dec 2004
    sorry forgot to reply, your method worked a treat!!
