Manitou Mezzer - Page 12- Mtbr.com
Page 12 of 13 FirstFirst ... 28910111213 LastLast
Results 2,201 to 2,400 of 2430
Thread: Manitou Mezzer
  1. #2201
    Sep 2020
    Quote Originally Posted by mike156 View Post
    If your pump leaks a bit, it's likely the o-ring in the swivel part or the o-ring that seals against the schrader valve. It's uually not an issue on new pumps, but with some use, I've had a couple different pumps start leaking a bit. It can help too lube the o-rings a bit. That small leak makes a big difference on small volumes (IRT and negative chambers like the Mezzer).
    A lot of pumps are just rebranded versions, not sure who the original maker is though. I found a cheap $15 mechanical pump on Amazon that had a hose with a zero leak valve and was able to take that hose off and put it on my more expensive digital gauge.
    Thanks guys. Yep the pump is leaking a tiny bit from the swivel, but I was more referring to the air loss when disconnecting from the +/- chamber (trying to do it quickly!). e.g. I can pump it up to say 45psi, disconnect it, reconnect it and it displays 38psi.
    The pump is advertised as loss free connection but that doesnt seem to work (red products shockmaster pro pump- same as the Rockshox one but with a different hose)
    Thanks also for the suggestion, I'll take a look into the syncros pump
  2. #2202
    Reputation: Velodonata's Avatar
    May 2018
    Quote Originally Posted by spicy View Post
    That's pretty typical, you always read low on reconnection because the hose and gauge need to refill before you get a reading. It should be consistent, though. Try it both slow and fast and see if there is a difference, that will help show if you are really losing air from the chamber or just from the hose and fittings.
  3. #2203
    Reputation: Dougal's Avatar
    Just prime riding season right now so don't really want to open it up right now. Although, I might pull it off and swap back to the Lyrik, I've changed bars and stem recently too. Wouldn't hurt to revisit where I think I was at anyway and could did into the Mezzer then.
    Am I right in thinking the Avy cartridge is more of a poppet system blended with shim stacks?
    The mid valve (second picture) has a spring loaded check plate with free float being petty limited. Seems like it's going to blow off like a poppet until the check plate reaches the spring cup, then it will preform like a more conventional shim stack with free float?
    I also have the FvAT/HSB (first picture) which appears to act in a similar fashion but in the basevalve side?
    It's making the gears turn on trying to figure out a way to implement something similar in the Mezzer.
    Mezzer mid-valve setup is a spring washer setup with a decent amount of stroke. Very different to the Avalanche setup you've shown. There is a little bit of room to run different mid-valve setups in the Mezzer but you need to do some custom machining.
    Owner of www.shockcraft.co.nz, Mech Engineer, Tuner, Manitou, Motorex, Vorsprung EPTC, SKF, Enduro
    www.dougal.co.nz
  4. #2204
    Jul 2017
    I was thinking more on the basevalve. I haven't had it apart, just looking at the pictures so I could be missing something pretty obvious. My thought though is to use shims with a larger ID so the whole stack could float on the shaft. Then have the HSC spring sit against a washer that floated on the shaft and applied preload to the floating shim stack. Low/mid speed would still be controlled by the shims but then the whole stack could blow off at high speeds.
    I could see how the mid-valve having the setup though might make for better LSC without harshness though as more fluid has to move through it.
  5. #2205
    Sep 2020
    Quote Originally Posted by Velodonata View Post
    I just swapped the hose with the one on my analogue RS pump (which has a longer threaded connector) and it's much better, seems like a much more normal amount of air escaping as I unthread it!
  6. #2206
    I don't see that solving any problems. Preloaded basevalves IMO feel awful.
    It'll take you half an hour to pull the whole damper out the top and get to the base-valve. Remove one of the doubled up shims, reassemble and rebleed.
    www.dougal.co.nz
  7. #2207
    Reputation: CCS86's Avatar
    Jan 2020
    Rode 30 miles and about 9k vertical ft of desert this weekend and by the end I had given up on trying to get support out of this fork and was just trying to keep my hands from hurting. Full open on HSC and like 8 clicks out on LSC. 60/93psi @180mm/215lbs. Had about 25mm of unused travel. Also raised the bars some so it didn't feel so low up front with the lack of support.
    Full open HSC and 8 clicks out LSC will not give you much low speed damping at all.
    I would try it with HSC 1-2 clicks in, from open, and LSC ~2 clicks out from closed. With it set there, I would play with different main/IRT pressure combinations to get a good feel of support, with appropriate bottom out prevention.
    You mentioned also changing your stem and bars, which can have a huge impact on how your hands feel. Maybe it is worth running your Lyric with the new bars to recalibrate. It would be a shame to blame the Mezzer for things your bars are doing. I really like the OneUp carbon bars. They are stiff in steering and compliant for bumps.
  8. #2208
    Jul 2017
    CCS, from earlier posts I was running a lot more HSC and LSC. Agreed on swapping back to the Lyrik and rebaselining. I definitely try to give parts a fair chance. Even revalving the Mezzer is fair in my mind.
    I swapped to the OneUp carbon bars (35mm rise), from raceface SixC carbon bars (20mm rise). I removed two spacers from under the stem. Also went from a 32mm stem to 40mm stem. In all, went up 5mm and forward about 14mm. The OneUp and SixC bars have the same angles to them so should feel similar in general.
  9. #2209
    Jul 2017
    Quote Originally Posted by Dougal View Post
    The Mezzer has a preloaded basevalve? That's what the HSC spring is doing, adding preload.
    I think to make it match the Avy basevalve though, there would need to be a travel limiter with what I mentioned above, so it can only blow off so much, then at higher speeds, the shim stack comes into play.
  10. #2210
    Have you checked that the fork can go trough all the travel without problems?
    Therefore use very low pressure and fully compress it.
    Im a tad heavier ~230lbs and run 74psi/104psi at 170mm. HSC closed and heavier shimstack, lsc half closed.
    The original compression damping is very soft on the mezzer, even full closed.
    Maybe you ride to much on the back, there not enoug weight on the handlebars or your impacts are just not heavy enough for using the complete travel. The mezzer doesnt waste its travel due to the irt system.
  11. #2211
    Jul 2017
    Symion, yeah, I don't disagree with what you are saying. If you look back to my previous posts in here, you'll see I was running MUCH firmer damping (HSC-2/LSC-1 from closed) to try and get support. While it gets decent support like that, it was beating the hell out of my hands. Over the 30 miles, I kept reducing compression damping to try and make it more compliant to avoid hand pain. In all honesty, I didn't mean to run HSC fully open, I think I grabbed it instead of the LSC adjuster at some point in the ride. The last 5 miles or so I had found a point that wasn't hurting my hands and I stopped messing with it. It was only at the end of the ride I realized HSC was full open.
    The entire ride I felt like I had too much weight up front though as it kept diving and just got worse as I opened it up. With the higher travel and raised bar height though, it wasn't terrible feeling. I could deal with it as is right now, but I know what a better fork feels like so I'm trying to figure out how to make the Mezzer feel like my Lyrik. Not to beat a dead horse, but my Lyrik has an Avy cartridge tuned for my weight and riding style, a Runt to mimic the IRT, low friction seals, burnished bushings and is well maintained. It's not a standard Lyrik I'm making the comparison to, it's a $1600 beast of an air fork and the only thing that could truly beat it would probably be adding a coil setup or going dual crown on top of those parts.
  12. #2212
    The Mezzer basevalve is only preloaded with the higher HSC settings. I don't run those. I run a shim-stack that does what I need.
    Running two different modes usually gives you an ugly transition between them.
    www.dougal.co.nz
  13. #2213
    Apr 2017
    When I went from 35 mm stem to 60 my fork (not mezzer back then) immediately needed more air as i guess you are putting more weight over the wheel or smth. You only added 14 mm but may still be noticeable, as in your next post say the fork feels divey. Maybe a few psi will put you there
    Odoslanť z M1 pomocou Tapatalku
  14. #2214
    Jul 2017
    Romulin, the fork felt divey before I changed the bars too. But yeah, rebaseling with there old fork is probably where I need to start.
    Dougal, wouldn't softening the shim stack for HSC also make for less LSC? Because even with LSC closed completely, the fork feels too soft without closing HSC to the second click from closed.
  15. #2215
    Jan 2020
    I have been playing with compression damping lately, getting some miles in with the HSC at +2 from open and LSC around -4, with some combinations in that neighborhood. Today, I put it back to HSC wide open, LSC full closed, and I just prefer it that way. Maybe we just all have very different personal preference for feel, riding style, and terrain. With it set this way (and maybe some extra LSC damping from Supergliss 100k), it feels super plush, but still supportive. I launch this thing off big drops, dive down steep, chunky trails, rail around berms, and it feels composed, supportive, and plush.
  16. #2216
    May 2019
    Stock compression shims:
    8x20x0.1, 8x17.5x0.1,78x17.5x0.1, 8x11x0.5mm
    Hey Dougal, can you confirm if I've read your comp shim stack correctly:
    1, 8mm (ID) x 20mm (OD) x 0.1mm (thick)
    1, 8mm x 17.5mm x 0.1mm
    7, 8mm x 17.5mm x 0.1mm - This can't be right...
    1, 8mm x 11mm x 0.5mm - This is the HSC shim...is that 0.5 correct?
    Seems like a pretty easy HSC fix if that 8 x 11 is really 0.5mm thick.
    Is that single 8 x 17.5 x 0.1 a typo, or the 7, 8 x 17.5 x 0.1 a typo?
    OR
    Did you mean there are 2, 8 x 17.5 x 0.1?
    Lastly, when you took apart the comp stack, did you also take apart and document the rebound stack also?
    Thanks in advance.
  17. #2217
    May 2017
    Quote Originally Posted by Twilight70 View Post
    OR
    Thanks in advance.
    There are two 17.5mm shims. These are stacked and they are curved. I just removed one of them and literally got back from the first test ride and I am so impressed with the difference.
    Fork now reacts much better to high speed impacts, really supple, and that slightly harsh feeling that I have been trying to dial out has gone too. In hindsight I don't think the fork was reacting quickly enough on chatter so I it was skipping over terrain. Ok to begin with but as the ride went on and I tired I found this skipping trait to feel exacerbated and at times difficult to manage the speed it needed to work. Now it feels like how I like a fork to feel, plenty of support from the chassis and enough LSC to hold it up when braking and it freely uses its travel appropriately with zero harshness.
    Now my EXT shock feels like it has too much HSC lol
  18. #2218
    OR
    Thanks in advance.
    That's a typo, I guess only one person read it close enough to realise!
    Stock was 2x 17.5mm shims. At some point (I don't know when) they removed 1x 17.5mm shim to cut the HSC down.
    I had revalved my fork early on to give slightly more compression damping than the new setup.
    www.dougal.co.nz
  19. #2219
    Yes a softer HSC stack gives you less LSC range. But it also lets you run more spring-rate which was probably compromised earlier.
    www.dougal.co.nz
  20. #2220
    May 2019
    Quote Originally Posted by springs View Post
    Springs, thanks for this! "Curved?" Do you mean it has a dish? If so, is the dish to help w/ that preloading lipped washer/spring seat or to fight against what that preloading lip is doing to that 20mm shim?
    Maybe just a bit of deets on you...your riding style and the bike you have it on? What's your wheels-down weight? Was your first ride on smooth or chunk, flat or steep, up and down or just shuttled, or a combo of all so you can gauge the effort you made on your fork? How old are you and do/did you used to race...basically, what's your skill level...so I'd have a clue how hard you can push a fork.
    Thanks again!
  21. #2221
    May 2019
    Hey Dougal! Thanks for the reply. Yeah, it was the enginerd OCD in me doing the reading
    So...what did you mean by "they removed...?" Do you mean the base tune coming from Manitou is now only 1, 20x0.1 and 1, 17.5x0.1 instead of 2, 17.5s that you posted from Jan or Feb? Is this found on MY21 forks, or just later builds of MY20 forks? I'm seeing they (Manitou) now has 29er/44mmOS back in stock...have you taken one of these since the restocking apart yet?
    Thanks again.
  22. #2222
    Thanks again.
    Yes that's exactly the change, but I don't know when they did it. I can't help with serial number or date change.
    I've had some 29" 44OS through. But I tend to not pull new forks apart that far. We'll pull a new one of those into our demo fleet shortly (just clearing out last seasons). I might get a chance then.
    www.dougal.co.nz
  23. #2223
    Jan 2020
    If you've ever gotten your IRT cap a little too tight...
  24. #2224
    May 2019
    Thanks for the clarification on the change. So by that then, the MY21 forks should be damn near perfect if they've addressed the bushing slop issue. Sound like I'll prob have pull the trigger and bought one before you've had the chance to pull one apart.
  25. #2225
    Reputation: elsinore's Avatar
    Jun 2005
    Manitou Mezzer
    Decided to take a crack removing extra hsc shim since I think it may help solve my harshness issue, and I have a spare busted damper to experiment on.
    When the assembly came out of the damper it fell apart a bit unexpectedly, so I just want to make sure I have this assembled correctly.
    Also, any tips on how to get the bladder seated back into the base?
    Thanks again everyone! This thread is amazing.
  26. #2226
    May 2017
    Anyone like to have a crack at explaining what they think removing one of these curved shims out the stack would achieve?
    Next question would be what would it achieve if one was removed and the curved shim was flipped so that the shim above was effectively folding over it?
  27. #2227
    Jul 2017
    Springs, best I can tell, that's not a shim. That's the compression check spring.
    CCS86, I don't disagree that HSC open, LSC closed feels the best. It just doesn't really have enough LSC though, that's why I tried more HSC so it brings the LSC knee higher up. It gets some of that extra support but also comes with a bunch more harshness. Ride this weekend, on the slow tech I ran HSC at 2. Once it opened up and speeds picked up, I ran HSC at 4 (full open). Felt fine like this, just use to a fork that does both without changing settings mid ride.
    Elsinore, that order doesn't look right. My post #2019 above has the complete basevalve disassembled. The shim layout is on the bottom. I didn't take that picture, but it looks like what I'd expect.
    Dougal, going back here. What I was suggesting before actually wouldn't be a preloaded basevalve at all anyway. It wouldn't be preloading the shims. It would be controlling the shim clamping load. The shims would flex initially like completely non-preloaded shims. Once your differential pressure overcame the spring force though, the clamp shim would move and allow the entire shim stack to move away from the face of the valve. This should make for substantially more flow area. I could see how this might cause some flutter though. But the simple fact remains, the Avy cartridge seems to work in a similar manner and it kicks the crap out of this damper. It does it on the mid-valve and the basevalve though and it also has some additional features that would impact the behavior.
  28. #2228
Name:	Manitou_Mezzer shims.jpg
    Removing one will likely give you soft and inconsistent closing. Too soft closing can mean it slams shut on change of direction and creates a knock.
    I do arrange them so the check shim can fold over.
    www.dougal.co.nz
  29. #2229
    Okay that makes sense. That gives you a softer knee effect than a poppet or edge pre-loaded shim. You'd need to run a firmer stack and modify the whole compression assembly to acheive that.
    Avalanche need to use a firmer mid-valve because open bath runs in an oil foam that is slightly compressible. The base-valves in that situation can't deliver expected damping force from small displacements in that foam but a mid-valve can. In a cartridge damper you've got solid oil so the base-valve can do what it should.
    My opinion is that once you have the right amount of HSC compression damping, you can run the right spring-rate and you don't need as much LSC as you think you need when battling a base-tune mis-match.
    The amount of damping in the first year Mezzer was about 20% more than I wanted and I compromised spring-rate to get the response I needed. With a revalve it does exactly what it should.
    I'm now a bit firmer on compression than the 1-less-shim tune.
    I ride on choppy terrain where any knee formed damper curve feels awful.
    www.dougal.co.nz
  30. #2230
    Ride More - Suffer Less
    Reputation: TraxFactory's Avatar
    Sep 1999
    Just received my Mezzer and really stoked to get this thing setup.
    I tipped the lower slightly and dumped a bit of oil during a travel height adjustment. I figured I should just replace the oil in the lowers at this point.
    I do have Supergliss 100K (thanks Dougal!) available now or I can get the Motorex 5W40 locally. California winter upcoming, will be riding in ~5-23C for a few months.
    What is the recommended oil?
    If I do switch over should I just top off with 20cc or thoroughly clean out then refill?
  31. #2231
    Quote Originally Posted by TraxFactory View Post
    Unless you lost all the oil, just run it. Change it after a few weeks break-in.
    www.dougal.co.nz
  32. #2232
    Sep 1999
    Dang, that makes a lot of sense. I would say it pissed out a good 10cc, Unfortunately I grabbed the oil pan and let them drain out.
    Get the 5w40, then switch over to SG100k after break in?
  33. #2233
    Yeah.
    www.dougal.co.nz
  34. #2234
    Finally-- I got replacement Mezzer (#2) for defective #1-- I was told by the retailer that #1 had the latest castings -- and it did have a green handwritten"B" on the label-- which I found out doesn't mean much. months Rode #1 at 180mm at assorted pressures some at recommended spec but mostly 10 -15psi less . with fully opened lsc/hsc /rebound -- did this for 2 months hoping the fork would eventually break in.-- all the time the fork basically sucked.
    Took it apart and found out that there was a ton of stiction/friction between the air piston ring and the inside of the stanchion. Sent the fork to Manitou and it turns out I had the older defective casting after all. Because of this the air spring piston was scratching the inside of the stanchion. Waited about 6 week and #2 arrived yesterday--it was manufactured Aug 2020.
    I put in on and it was magic from the get go!
    plush! plush! and that is even without playing any pressures. hsc/lsc--granted my ride was wasn't for very long-- but the fork already felt leagues better than the defective fork.
  35. #2235
    Jan 2020
    Glad they got you sorted!
  36. #2236
    Rocks belong
    Quote Originally Posted by locominute View Post
    Mind telling me more about this?
    I thought the defective castings were the lowers, but you're talking about the upper CSU.
    I did a travel change when my fork was new and seem to have been struggling with air spring friction. I pulled it apart to schlube 'n lube everything and noticed the grease around the air piston had black crap in it (it was clean Slickoeum when I put it back together).
    Last week, during initial compression (after the bike would sit overnight), there would be a dang squeak/squeal that sounded like dry rubber running across glass or smooth metal. It would loosen up, but the fork would feel like crap until you got it cycling.
    I just pulled the fork apart (again) and lubed the snot out of everything on the air side. IRT shaft & seal, air piston seal, air piston shaft, air piston seal head, etc.
    I even went as far as putting some oil in the IRT, like DSD recommends with their RUNT.
    I like 'em long, low, slack and playful
  37. #2237
    Rocks belong
    Quote Originally Posted by 06HokieMTB View Post
    To clarify this... I did a road trip to St George/Hurricane and Moab. The dang air spring friction seemed to get really notchy with the bike sitting over night. Each morning I started connecting my air pump to the main (lower) air valve and cycling the fork a few times, using my chest to push down on the handlebars. That seemed to get everything loosened up and moving again and was enough to get me through the trip.
    I lubed the snot out of the fork yesterday and am riding Angel Fire bike park tomorrow - guess we'll see if I fixed it.
  38. #2238
    The way Manitou explained it to me is that
    when the lower casting bushings are not properly manufactured it screws up the the alignment inside the stanchions which causes the air spring to be wonky and then scratch the inside of the stanchion
    when I took off the lowers there was still oil and lube
    BUt I added some more oil and I also put in a ton of slick oleum and still the IRT and the air spring were still sticky inside the stanchion.
    This I would find somewhat odd since I would imagine that the IRT would not be affected as much versus lower down from the crown.
    luckily, Mezzer #2 is wonderful from the second I hopped on
    I toyed with the idea of selling Mezzer #2-- so glad I did not.
    btw
    what is the manufacturing date of your fork?
  39. #2239
    Jan 2020
    I used to notice a little bit of "judder" on a cold fork. After compressing it maybe 10 times it always smoothed out, so it was never a concern on the trail.
    I recently put maybe 10 drops of Supergliss 100k on top of the air piston and on top of the IRT piston (plenty of Slickoleum already in there, and the judder is gone.
  40. #2240
    Rocks belong
    btw
    Is that on the fork? Or only on the box?
  41. #2241
    May 2017
    I removed one of the springs and the difference has been much greater than I was expecting. The stickiness that some have been commenting on, whether it be the quad seal or whatever has almost gone. It feels like the friction has reduced and the fork is now considerably more active over repeated hits which has helped me with hand/arm pain on longer runs.
    The damper was bled correctly prior to the change and I'm using the same 5w Motorex oil so there is no change there, just the removal of one spring holding that check shim. I didn't touch the air side so no new lube/service feeling. I kept pressure the same 92 IRT 52 main, the HSC is 3 from closed, LSC 4 from closed and rebound is 4 from closed. I did have the rebound 7 out from closed but my rear shock (EXT Storia) seems to run slower rebound so I slowed the front to match and it seems to now quite balanced. If anything the Storia now feels like it has too much HSC as it feels a little abrupt on square edge stuff when the bike is around the sag point or higher in its travel but that's another story.
  42. #2242
    May 2018
    I can see where if the lower bushing was so screwed up as to be effectively out of alignment that the lower leg would no longer be lined up with the stanchion, and the bottom of the lower where the spring shaft mounts would be affected the most, putting the shaft under a constant side load, which would also affect the air piston. Yup, that would suck and it would rapidly degrade the air spring.
    The IRT is entirely independent from all of that though, it sits up top all by itself, it just needs to be properly lubed to start with, which is not how all of them were coming out of the box. Glad to hear they got you a good one and it is working as intended.
  43. #2243
    box
  44. #2244
    Bigger is better!
    May 2005
    Quote Originally Posted by CCS86 View Post
    Are there any downsides of doing this?
    (I donít consider ęa few dropsĽ migrating down into the neg chamber a real issue..)
  45. #2245
    Quote Originally Posted by langen View Post
    Downside is the oil can wash out the grease as it thins out and can migrate to the lower negative chamber. But if you have a feel for when your fork needs maintenance and don't ride it for a year without air spring maintenance you'll be fine.
    www.dougal.co.nz
  46. #2246
    Jul 2017
    FWIW, if you mix grease and oil together into a paste, it works pretty damn well for the air spring side. It's thick enough to stick to everything still, but not so thick that it can't slowly slide back down the stanchion. Straight grease usually just gets pushed out of the operational zone and then stays there. The paste will work it's way back into the operational zone but didn't really migrate between the different chambers.
    I did this with my Runt, mixing dynamic seal grease and Plush 10W oil. It noticably made the Runt operate smoother. I do the same in the Lyrik air-spring and when I service it, all the grease and oil stays in the positive side, despite there being the equalization dimple. Did the same in the Mezzer as well and haven't had any issue with it coming out the air valve when messing with air pressure.
  47. #2247
    Jan 2020
    Yup, I think you nailed it there. Even very thin grease, like Slickoleum, forms a ring above the air spring piston, with the stanchion left wiped nearly clean by the seal.
  48. #2248
    The bulk gets wiped, but it leaves a working film. It's keeping that film replenished which is the challenge for all lubrication.
    www.dougal.co.nz
  49. #2249
    Dec 2015
    Could anyone tell me the volumes of negative, positive and IRT chamber? Any stroke. Just want to model airspring curve for compare.
  50. #2250
    Apr 2014
    @dougal how long are you recommending service intervals?
    I need to round up oils, grease, and damper bleed tools. Its got about 700 miles on it now. I was going to try and do a complete service on it before our trip mid next month.
    What do you recommend for it
    Motorex Supergliss 100k in the legs,
    Motorex Fork oil 2.5w for the damper ? Or your Green oil I am a 220lb rider.
    Looks like the SuperGliss 100k is not readily available in the US from what I am seeing.
    Then I just need some Slickoleum ...
    Jul 2020
    So a while ago I had a CSU creak, which manitou took care of quick fast and in a hurry. No issues since. Iím hoping they did a service while it was there and at least replaced the oil.
    But if they didnít, what syringe are yíall using to put oil into the fill ports on the back?
    Also I noticed today I have a tiny bit of oil on/around the rebound knob. Not enough to really see but just enough to feeel a little oily and catch some dirt. Is that normal?
  52. #2252
    Quote Originally Posted by TXrocks View Post
    I just bought 250 mL from Dougal - $35 shipped to PA, USA. That said, I have no idea when it will arrive, but Iím not in a rush (probably wonít put it into the fork until spring).
  53. #2253
    Jul 2017
    Alright, this fork is going to kill me. Lol
    It keeps getting hung up on large objects (8-12" rocks) that weren't an issue on my last setup...
    Strangely though, it's just enough to make things sketchy but not toss me on my head. It will hang up, toss me forward and then about the time I expect it to be all over and for it to dive hard and finish the job, it some how pops up over the object. It's like there is enough support deeper in the travel, but from SAG to like 100mm of travel, it's too soft.
    I'm not using the last 40mm of travel unless I hit something really hard, and even then it never uses the last 25mm. But at the same time, it just feels soft... Everywhere. Except for of course the high amount of harshness over braking bumps.
    Is the wheel not able to get out of the way quick enough? Or is it not firm enough initially to push me up over the object?
    I had zero issue getting my last fork setup but man, I can't get this thing to work. I want it to though. I really do.
  54. #2254
    Rocks belong
    So you have to use the SRAM dynamic seal grease instead of Slick Honey?
  55. #2255
    Jul 2017
    Just on the air piston and IRT. Slickolium and oil in the lowers.
  56. #2256
    What pressures are you running?
    Have you done anything with rebound or just removed the shim on compression?
    www.dougal.co.nz
  57. #2257
    Jul 2017
    61/95 on air
    Haven't touched the damper yet internally, if that's what you mean? I'm swapping back to the Lyrik after today's ride so I can rebaseline. Maybe something else is throwing things off, so I want to eliminate other variables. It's pretty consistently felt like what I described above though since my first ride on it when the only thing that changed was the fork.
    I've got a 37.07mm burnishing die being made that I was going to use and then if there is a shim stack change that makes sense, I'd do that too.
    Up for suggestions, but I'm at a loss as in general, it feels too soft and unsupportive. But doesn't use much travel and it's harsh at speed.
  58. #2258
    Jul 2020
    How much do you weigh? Those are odd issues.
    Iím at 183 pounds and run much lower pressures than you but havenít felt anything that youíre scribing. I run about 48 main 60 irt to make it feel a little more progressive. What is your LSC, HSC, and rebound setting at?
  59. #2259
    Jan 2020
    I would definitely pull the air spring and damper to check chassis fit before burnishing. I haven't heard a single report of tight bushings in a Mezzer. If anything they run on the loose side.
    When you say "It keeps getting hung up on large objects (8-12" rocks)." Can you explain what you mean? I'm having a hard time picturing how the fork can get "hung up" on an object by being too compliant. You are moving forward. In order for the wheel to get over the obstacle, it has to move up. The more resistance to this, from the spring and damper, the more you and the bike chassis lose forward momentum, and get directed upwards.
    When you disconnect your pump, the front wheel is off the ground and pulled to top of stroke? With the pump connected can you easily push the fork to full bottom out?
  60. #2260
    61/95 on air
    Drop a shim in the damper (gives you my2021 tune), reduce irt to 90 psi and I think you'll be sorted.
    Sent from the Shockcraft mobile typewriter
    www.dougal.co.nz
  61. #2261
    Jul 2017
    I've been wondering if you can feel how tight the bushings are with the wipers still in?
    I'm not saying it is for sure too compliant causing it. Just that it's soft feeling in general.
    What it feels like is the tire stops briefly, your momentum compresses the fork and your weight keeps moving forward. About the time I think I'm heading over the bars, the tire starts going again as it rolls over the object. Usually when this has happened, it's been at lower speeds in a rock garden. Today though, it was while I was grabbing a hand full of brakes at high speed through some rocks before a tight switch back. Came off the pedals right when I hit the rocks and rode 5-10' with all my weight on the bars and probably the back tire off the ground after it rolled over the rock. Not sure how I stayed on the bike. Lol I feel like the fork saved my ass... But caused the issue in the first place.
    Yes, fork fully extended when removing pump.
    Nope. If I put about 80% of my weight on it, I can get it to fully compress. But not easily. I open the vent valves though and yes it easily compresses.
  62. #2262
    Jan 2020
    You might be able to feel if the bushings are really bad, but I think the wipers have enough influence to skew the result. I certainly wouldn't burnish my bushings without a wiper free test.
    Technically, you shouldn't remove and reinstall wipers. I designed a 3D printed removal tool (and a driver) let has let me pop them out without any damage. I could sell you a set for pretty cheap if you wanted.
    Something sounds wrong there. Have you tried opening the bleed screws, or cracking the foot nuts loose? It sounds like your airshaft valves are partially clogged and/or pressure has built up in the lowers. I can try to check how much actual force it takes me, but with the pump connected, I can compress the fork fully with much less than my full 156 lbs.
  63. #2263
    Jul 2017
    I'm running it at 180mm? If you are running less travel, you'll have a lower compression ratio? It easily compresses until about the last two inches, then it quickly ramps up. I've had the lowers off to do a service and everything looked good. Like I mentioned, if I take the vent caps off then with the pump connected it easily compresses to the bump stops. It's the air build up in the lowers that's causing the high force, without a doubt.
  64. #2264
    Jan 2020
    I'm running at 145mm, so I definitely have lower CR in the lowers. I just wouldn't expect it to have such a dramatic effect.
    What is your static sag on the fork?
    It sounds like most of your complaints would be addressed by more main pressure and less IRT, assuming everything else is in good working order. I would go [+2psi main / -2psi IRT] increments and see how it feels.
  65. #2265
    Aug 2020
    Alright, another setup help post =\. Rode the Mezzer for the first time yesterday. Comparing to a 2021 Lyrik Ultimate. I rode a trail I'm very familiar with.
    Used 20mm less travel with the Mezzer. Overall it felt better and eliminated arm pump that I was experience with the Lyrik. However, it's feeling soft off the top, with a rapid ramp up to short mid stroke and real firm bottom. It doesn't feel right yet, definitely feels too progressive. I setup the air based on the calculator linked earlier in this thread. Everything else set in the middle just because I had no idea what to try out for baseline.
    Primary terrain is PNW steep techy chunk with drops to flat and some jumps. I need enough pop to handle the drops & jumps, while maintaining enough compliance to not fly off the ridiculous amount of roots and rocks. It'd be nice to have a setup for flow as well, every once in a while some fast flowly relaxation is a nice break.
    For reference, I'm a low-intermediate rider so my form and balance is likely trash most of the time.
    5'10", 184#, about 190 - 193# kitted
    2020 Specialized Enduro S3...long and slack
    170mm 29" 44 OS
    50/83
    HSC 2
    LSC 5
    R 5
    20% static sag
    Lyrik setup for reference. Settings are from open:
    85 psi
    HSC 0
    LSC 2-3
    R 4
    1 volume spacer
    15% static sag
  66. #2266
    Jan 2020
    Quote Originally Posted by fireflywa View Post
    170mm 29" 44 OS
    50/83
    HSC 2
    LSC 5
    R 5
    20% static sag
    The beauty of the IRT system, is that you can tune the main air for off the top and mid-stroke feel, and dial in bottom out protection with IRT pressure. Especially with the hydraulic bottom out, you can run less progressivity.
    I would try 52 / 80 and see how that feels.
    If you need more support, bump the main in 1-2psi increments, and keep dropping IRT until you just bottom out on your biggest drop. Do yourself a favor, and make a true bottom-out mark on a stanchion with a small piece of tape: clean the stanchion with some alcohol, near the crown. Connect your shock pump to the main chamber and leave it connected. Bounce the fork off the bottom a couple times. Then, put your tape just flush with the top of the o-ring. Being able to accurately see travel available/used is key to dialing IRT pressure in.
  67. #2267
    Sep 1999
    I am no tuning genius but wouldn't you start with backing off the compression slightly then play with the psi +/- ?
  68. #2268
    Jan 2020
    I personally run pretty close to wire open on HSC and full closed on LSC.
    People have different personal preference on that, and if he is running +2 from open on HSC, that's not going to keep him from using travel.
    If it feels too progressive, it probably is.
    Sent from my Pixel 4 using Tapatalk
  69. #2269
    Jul 2020
    Can anyone tell me what to use to get oil into the fill ports? I canít find the manitou syringe in stock anywhere
    Also when a fork goes in for warranty work do they also service it? Tried emailing Manitou about it but havent gotten an email back in a week.
  70. #2270
    170mm 29" 44 OS
    50/83
    HSC 2
    LSC 5
    R 5
    20% static sag
    85 psi
    HSC 0
    LSC 2-3
    R 4
    1 volume spacer
    15% static sag
    Is that 20% in the attack position or just sitting on the saddle.
    I would drop the main and the IRT by a couple of PSI and go from there.
  71. #2271
    Reputation: Curveball's Avatar
    Aug 2015
    Quote Originally Posted by megablue View Post
    I get my syringes for free from the local pharmacy.
    Riding Washington State singletrack since 1986
  72. #2272
    Boom bap ambassador
    Reputation: silentG's Avatar
    Feed stores like Tractor Supply and the like are good sources for veterinary syringes which come in a variety of sizes and types for pretty cheap
  73. #2273
    Quote Originally Posted by POAH View Post
    He already has a fork that's too soft in the early stroke and is too progressive, dropping the pressure in both would just make it worse.
    Add air pressure to the main, and reduce the IRT pressure. This firms up the spring rate where he needs it and reduces the progression.
  74. #2274
    Reputation: 006_007's Avatar
    The fill ports on the lowers are an M5 - according to Dougal a Shimano bleed kit or a reverb bleed kit will thread right on!
  75. #2275
    Quote Originally Posted by aerius View Post
    Is it too soft though or is he just used to a lyrik that is 90% reliant on the air spring?
    www.dougal.co.nz
  76. #2276
    not convinced his fork is too soft with those settings, travel and his skill level. If he was running a lyric at 15% sag in the attack position then he is going to be used to a very stiff air spring.
  77. #2277
    Aug 2020
    Thanks for all the replies (too many to quote on a phone).
    The sag numbers I stated are in the attack position. The Lyrik was probably setup too stiff...I found a setup that worked pretty well for the terrain I ride and didn't mess with it after that. Less air resulted in bottom outs and I didn't like the feeling of an added volume spacer.
    I'm not sure how soft it's supposed to feel off the top. Right now it's considerably softer than the Lyrik until about halfway down the travel, then it ramps up hard. I like the idea of a little more main and a little less IRT, but I also like how well it soaked up trail chatter. Felt like it was floating over fast sections while still super planted. A noticeable difference was no arm pump at all whereas with the Lyrik I'd have to take breaks for my arms to recover.
    Maybe something like more main, less IRT, HSC one more click open, close LSC a click, and open rebound a click? I probably have some of that backwards...the Lyrik only has a couple usable clicks of each setting so it's a bit different having adjustments that actually do something.
  78. #2278
    Jan 2020
    I think you should try that next time out.
  79. #2279
    Rocks belong
    I'm only running my Mezzer's HSC 1-click from open (I believe that is 3 clicks "out" from closed)
    I've found I prefer the support to come from the air spring and not the damper, so I run very little LSC/HSc
  80. #2280
    Feb 2014
    Use Lsc, but only max 1 click hsc from open and handle the rest with the pressures.
    Main for initial suppleness until ride height and feel match your preference and the IRT for support and bottom out.
  81. #2281
    I'm a bit lighter than you but run the same travel (27.5) but guessing I ride more difficult trails. Transition patrol mk1.
    my settings are 50/75 and both HSC/LSC 2 from close (turn the dials fully closed then turn them back 2 clicks). Rebound is to suit. I run my front tyre around 23psi (wild enduro + huck norris)
  82. #2282
    AKA Mr.Habanero
    Reputation: panzer103's Avatar
    So hey, can the Mezzer be reduced to 120mm? I know it can be reduced to 140 but can it unofficially be reduced to 120?
  83. #2283
    May 2018
    Quote Originally Posted by panzer103 View Post
    It can be, with or without using more spacers. But you are getting into the weeds on it's intended usage and tuning may get wonky.
  84. #2284
    Mr.Secret
    Reputation: R.T.R.'s Avatar
    Mechanically you can reduce it as short as you want.
    Excellent results with one of my Mezzer's set at 130 on my Ibis Ripley V4.
    The Mezzer's so simple to work on that if you've the travel reduction spacers give it a go.
    You can also give it a try without disassembling just by connecting your pump to the positive air then compressing the fork to 120.
    ...think we'll ever get outta' this world alive ?...
  85. #2285
    Jul 2017
    I started making a solid model of the Mezzer internals.
    This is a March 2020 build of a 27.5 Mezzer Pro set to 180mm of travel.
    Some parts I had to estimate slightly as it would require dissassembling things that I don't want to take apart. The limits to the error are very small though, like +/- 0.5cc MAX.
    Here are the volume equations I came up with. Anybody able to compare to their own numbers?
    Negative Spring Volume Equation
    Y[cc] = 0.8081438*X[mm] + 46.93218
    Positive Spring Volume Equation
    Y[cc] = -0.8552981*X[mm] + 173.3587
    IRT Volume Equation
    Y[mm] = -0.7767529*X[mm] + 61.30490
    IRT Positive Spring Volume Adder
    Y[mm] = 0.7767637*X[mm]
    Travel Spacers are 2.782cc per spacer (2 required per 10mm)
    Maximum Travel being 180mm on the main airspring and 67mm on the IRT. The IRT Positive Spring Volume adder is the volume that gets added to the positive chamber as the IRT compresses (use IRT position, not main spring position).
    These equations should be pretty useful for coming up with a spring calculator. I'll get there, but I want to include the lower leg volumes as well. I think I'm just going to measure it directly instead of trying to model it though.
  86. #2286
    IRT Volume Equation
    I've got about 5cc more negative and IRT volume. Positive is pretty close. Whole thing is modelled up.
    www.dougal.co.nz
  87. #2287
    Jul 2017
    What do you have for shaft ID?
    I didn't take apart the shafts so it was a guess at 7mm. Would definitely have the biggest impact on volume.
  88. #2288
    Jul 2017
    Actually, just did a quick sanity check on the IRT and if you negated the shaft material volume all together and ignore the material in the cap where the threads are, it comes up to 65.4cc.
    Wonder if something changed because there is no way I'm 5cc low on volume for the IRT. 7mm vs 8mm shaft ID is like 0.8CC so it's not that.
  89. #2289
    May 2018
    The IRT shaft is hollow other than the end of the bolt at the bottom and the little bit of the valve stem. It's part of the volume.
    Negative spring should also include shaft volume minus however much volume the internal connector rod takes up.
  90. #2290
    Jul 2017
    Yep, I accounted for hollow shafts and made a reasonable estimate on the valve piece that's inside of the main shaft. See the attachments. Sorry for the quality, I have the model on my laptop that I don't connect to the internet, I'll grab some high res images at some point.
    That's what I'm saying, even if the shaft didn't exist at all and you got rid of the threaded section of the IRT cap, I'm still not 5CC low on the IRT. I have to wonder if maybe something changed on the IRT from what Dougal measured.
    The place where I'm unsure is the shaft looks like about 1.5mm wall thickness, so 7mm ID. If I'm wrong and it's 8mm ID, the difference is only 0.8CC larger volume. More likely though, is an 8mm bolt and the minor thread diameter puts it at ~6.5mm inside diameter.
    Edit: the other unknown on the negative spring side would be the hard plastic stop at the seal head. I have it as solid plastic. I could see this being hollow inside? Probably a couple CCs in there I'm missing.
    Attached Thumbnails Attached Thumbnails Manitou Mezzer-img_20201026_081959%7E2.jpg
  91. #2291
    Jul 2017
    Outside of the solid model, I did notice on the damper side oil and grease has been spraying up the stanchion through the damper ring. Also looked like a small amount has come out of the damper bleed port, just enough to leave a residue path down the side of the stanchion.
  92. #2292
    May 2018
    Cool, yeah sorry I misunderstood what you were saying about the shaft. That is a significant difference, it would seem that the shaft length would have to be different to account for so much? Compared to that cutaway drawing Manitou put out, if anything I would have thought you would be very close or a shade over, not several percent under. But we don't know if it is spot on to production forks, and something else may have changed. Nice work.
  93. #2293
    May 2018
    That's something I still wonder about, the gap is so narrow it seems like under any quick deep compression there would be something of a jet of air and whatever went along with it occurring. Which should be limited to bath oil. And even a variable spring rate effect from the restriction and compression speed. But the real question is does it make a meaningful difference in anything? And does opening up the gap as some of us have done have any other effect than making drainback easier?
  94. #2294
    Jul 2017
    Yeah, my concern is that under compression, it's going to blow air past the o-ring, but under extension, your are going to create a lower pressure in the lower and grease/oil is going to help seal that o-ring up. If anything, I think this might impact rebound more than compression.
  95. #2295
    May 2018
    Yeah with the difference in volume between the damper side lower leg and the inside of the stanchion at bottom out, it seems possible it could briefly go negative pressure in the lower if the restriction were significantly gummed up or acting as a check valve. So further justification for opening up the slots in the cap? Or still not enough of an effect to notice?
  96. #2296
    Jul 2017
    Pretty likely I'll modify it but I still need to model it up as looking closer might still make it apparent it's a non-issue.
    37.07mm burnishing die showed up today too.
    For now, I put the Lyrik back on so I can dig in further on the Mezzer without having the bike down. Although it snowed yesterday anyway so getting a fair test on any of this might be hard.
  97. #2297
    May 2018
    Cool, very interested to hear how the Mezzer takes to the burnishing treatment.
  98. #2298
    Jun 2014
    Got my first rides on the Mezzer this weekend after 18 months of trying to make a Fox 34 SC feel right. Blown away at the difference so far. One click makes a difference. Adding damping does not make it feel like dog sh!+. Supportive without harshness (even with my toddler riding along on Macride for a bit). Can't wait to get it dialed. Wish I would have made the swap sooner.
    Quick question...without reading all the comments and deciphering all the million types of oils you guys use, what oil(s) (available in US) do I need for basic service. Will be traveling next year and need to bring essentials along.
  99. #2299
    May 2018
    Quote Originally Posted by GatorXman View Post
    Unless you also plan to service the damper, bath oil and some Slickoleum are all you need.
    This is the stock bath oil:
    https://www.amazon.com/gp/product/B0...c=1&pldnSite=1
    And this is the damper oil:
    https://www.amazon.com/Maxima-59901-...ldnSite=1&th=1
  100. #2300
    Jul 2017
    FWIW the Motorex stuff might be at your local motorcycle store. I got it for about half the price local compared to what I could find it for online.
    I guess I need the damper fluid too...Looks like the WPL 2.5wt I have is very close to the same viscosity with a better viscosity index. Should work.
    FWIW, there is decent drag on the stanchion with the seals in. If I do one stanchion at a time, the damper leg will keep moving with gravity once it gets started. Not the case on the air-spring side. I think burnishing is going to help. I ordered new seals though so I'll pull them and test it without seals too.
  101. #2301
    Jul 2017
    Modeling this fork up has clarified some things. I think I need to model the Lyrik now too though for comparison.
    Something that would look very interesting to try is a coil setup that maintains the sealed lowers on both sides. If my model is correct, you actually pick up about 240lb of progressive bottoming force from the lowers if you sealed the upper stanchion on the damper side too. Between that and the HBO of the Mezzer, this fork might be serious business with a coil.
  102. #2302
    Reputation: rupps5's Avatar
    I would like to reshim the mezzer. Is there a damper rebuild guide? I looked but could not find one. Like to know what I'm getting into before taking it all apart.
    Evolution Training Cycles
  103. #2303
    Reshimming the mezzer was easier than I thought it would be.
    Stock shim stack:
    20x.15
    17.5x.15
    17.5x.15
    6x.50
    Took out one of the 17.5 shims. we'll see how it rides
  104. #2304
    Jul 2017
    The plot thickens...
    Attached Thumbnails Attached Thumbnails Manitou Mezzer-img_20201029_171703.jpg
  105. #2305
    Jan 2020
    Now that's a custom tune!
  106. #2306
    Jul 2017
    Let's see how Hayes handles an issue after the customer took it apart...
    I wouldn't have gotten into it had I thought there was a real issue, just thought maybe people where overselling this fork...
    Attached Thumbnails Attached Thumbnails Manitou Mezzer-look-good-5493500d27.jpg
  107. #2307
    Reputation: bigdrunk's Avatar
    Yikes! Looks like you had a valid beef with how your Mezzer performed. At least you have a lot to look forward too after that washer gets replaced.
  108. #2308
    Jan 2020
    I would recommend calling them. They were super helpful and quick the first time I reached out to them.
    I'm excited for you to finally get to ride a proper Mezzer and to hear your results.
  109. #2309
    So that's a preload shim caught and crimped during assembly?
    Told ya it was too much HSC!
    Manitou will look after you. Give them a call.
    www.dougal.co.nz
  110. #2310
    Jul 2017
    Indeed, it definitely had some...not great...damping.
    Just some more info though related to earlier posts.
    Measured the volume of the 27.5 lowers to be 423CC. This is to the top of the wiper seal, with the foam rings in and greased up so they didn't absorb anything, all the other grease and lube cleaned out though. The stanchion looks to sit 132mm past the top of the wiper when at 180mm.
    Lower Leg Volume Equation
    Y[cc] = -0.9966911*X[mm] + 267.4178
    This puts lower leg volume at 88cc at bottom out. 20cc of oil on top...Things get squishy and high on pressure, for sure.
    I also started looking into replacement HSC springs. Indeed, the HSC spring does not touch the spring seat in the full open position. The stroke range on the adjuster goes from 8.5mm of clearance to 4mm of clearance. The spring is for a 10mm shaft, 15mm OD. Free height of 7mm. I did some ROUGH measurements using a scale and a caliper and got ~1100g/mm on stiffness.
    I've found a couple springs that are ~half the rate and would provide either small free play or slight preload. I have one that would basically take what position 1 is (one click in from closed) as the max setting and then go down to ~0 preload at full open position.
  111. #2311
    Internal volume is the same for 27" and 29". They moved the axle and brake position and offset on the casting to change wheel size.
    Are your discovered springs wafer type or coil?
    www.dougal.co.nz
  112. #2312
    Jul 2017
    Stacked wave disc with flat ends. Same as what's in it.
    https://www.rotorclip.com/
    Not sure what their pricing is like though.
  113. #2313
    Jun 2014
    So I could just buy a set of 27.5Ē lowers to convert my 29er (51mm) Mezzer?
    Sent from my iPhone using Tapatalk Pro
  114. #2314
    Quote Originally Posted by MsvSpaz View Post
    Yes. It'll be 44mm offset as a 27".
    www.dougal.co.nz
  115. #2315
    Jun 2014
    Great to know.
  116. #2316
    Dec 2013
    I see the Mezzer is on sale again. This fork has a great price to performance ratio that's for certain.
    Is there an update in the works? I'm always a bit suspicious when I see product being sold off at a discount when demand is very high as it is now.
  117. #2317
    Jan 2020
    Quote Originally Posted by Suns_PSD View Post
    They are about to release the zero-flex, zero-friction, zero-stiction, zero-hysteresis version; with bushings developed for world-class bulldozers.
  118. #2318
    May 2018
    I don't think you can make that inference in this case. The sale is across every product in the entire Hayes line of brands, which they seem to do every so often. If only they could keep the entire line in stock.
  119. #2319
    Dec 2015
    Im impressed with mezzer air spring system. 1,5x POS/IRT ratio, ofcourse approximated. Without lowers pressure buildup.
  120. #2320
    Jan 2020
    That's a nice looking curve!
  121. #2321
    Jul 2017
    Here was what my model came up with. The Lowers have a pretty big impact. The coil with lowers assumes the spring exists in the upper stanchion and the bottom of it is sealed off to get the ramp up of the lowers air pressure.
  122. #2322
    Reputation: Tubbsy's Avatar
    Hi everyone,
    I have a new Mezzer and am about to delve into trying to get the setup nailed.
    The blue rebound adjuster at the bottom of the fork seems incredibly stiff. Should it turn easily? I see there's a small Allen bolt inside it, but from looking at the service manuals this is for fork disassembly.
    Could it be done up too tight from factory impeding movement of the adjuster?
  123. #2323
    Feb 2014
    Quote Originally Posted by Tubbsy View Post
    Hi everyone,
    Yes, lossen it and then turn it fix to the pointythat the rebound adjuster stil moves freely enough.
  124. #2324
    Quote Originally Posted by bansaiman View Post
    Thanks Mate.
  125. #2325
    I serviced my original Mezzer today for it's new owner. Realising in the process that this fork with over a years use had no seals replaced and was only lubed up for travel changes.
    New owner gets the new lower legs. I never had a problem with the original bushings but the original bumpers floated around a lot.
    My new Limited Edition Mezzer will be shipping soon. I still have no idea what it's going to look like!
    www.dougal.co.nz
  126. #2326
    Jan 2020
    Hi everyone,
    No, the tension on that bolt should have nothing to do with the adjuster effort.
    It is worth disassembling though to clean and inspect. If the o-ring is totally dry, it could cause extra friction.
  127. #2327
    Thanks for that. I've only just built the bike up and hadn't spent any time on this yet.
    Turns out making the first turn of the adjuster needed quite a lot of force for whatever reason, but now it clicks silkily all the way round.
    I didn't loosen the bolt, so all good now I think.
  128. #2328
    Dec 2013
    Seems like the Mezzer has a superior chassis, and air spring design compared to the big 2. Is it possible to install an Avy Cart in to a Mezzer? Maybe needs a custom machined top cap?
    Thoughts?
  129. #2329
    Jul 2017
    Post #2304
    My damper was damaged internally from the factory. Every concern I have had about performance needs to be tossed. Hopefully it resolves the poor performace and this fork becomes awesome.
  130. #2330
    Feb 2014
    Thoughts?
    First try, if you do not like it stock, custom shim Tuning. Made my fork more supportive / controlled through stronger shimstack but more sensitive as well with thinner oil. This fork really rocks. But witj custom topcap you could use another cartridge, of course.
  131. #2331
    May 2017
    My Mezzer is still performing well but I cannot keep the damper side bath oil in the lowers for longer than about 6 rides. It migrates up and around the damper and there it stays. Hayes recommended removing the o ring in the white plastic bumper in the stanchion which I've done and I'll keep an eye on it but I'm surprised it isn't a common issue given there isn't much scope for variation. Not like my fork is any different than others.
    For info Supergliss 100k took the longest to get up there but given the damper is ingesting fluid and 100k and damper oil don't mix well I changed the bath oil on that side to 5w Motorex (same as the damper) which given the lesser viscosity explains the rate of suck up.
    I've shrunk the Mezzer to 140 and it's now on another bike whilst I test out the Ohlins M2 coil in it's place. First ride showed many similarities and a couple of decent differences between the two.
  132. #2332
    Jun 2005
    What oil are you using in your damper?
  133. #2333
    Apr 2014
    Has anybody had luck finding supergliss 100k in the USA? I am hoping to get around to suspension service before our trip in a couple weeks.
    THANKS!
  134. #2334
    I just bought some from Dougal (shockcraft.co.nz) and it was ~$35 USD and took two weeks to get to Philadelphia from NZ.
  135. #2335
    Reputation: ColinL's Avatar
    Feb 2012
    Quote Originally Posted by johnsogr View Post
    hmm when you say things like that, it's tempting to order a tuned mezzer from dougal. have him go through it before shipping at the very least...
  136. #2336
    Jul 2017
    After a week of waiting for a response on a warranty request through Haye's email system I gave them a call and it sounds like a new damper is on the way now. I must have just slipped through the cracks on their email system.
    FWIW, I've been riding the Lyrik and it's every bit as good as I remember. It does feel a touch high on the front now though after the riser bars. I did the riser bar to make up for the lower feeling front on the 180mm Mezzer compared to the 170mm Lyrik.
  137. #2337
    Reputation: ungod's Avatar
    Does anyone have info on how to properly disassemble the damper? I took it out last night intending to remove the extra HSC shim. I see a few ways to start disassembling it, but I got worried about doing something wrong and ruining my weekend so I backed out.
    Since I had it out, I added some "like water" to the damper to thin it out a bit, and it made a noticeable difference on my ride today. I was able to run a bit more air pressure on both the high and low side, which kept me more in the mid-travel while still feeling plush. It cut down the pedal bob without needing LSC and gave me more rebound to play with. Definitely a move in the right direction.
    Still, I'm preferring the HSC wide open, so I need to either add more "like water" or remove that extra compression shim.
  138. #2338
    Sep 2019
    The mezzer pro fork feel harash at the initial stroke.
    i reduced the air pressure at both to 3/5 of the recommended air pressure.
    but the fork still feel harsh overall. (and at the initial stroke)
    Does anyone have the same problem with me?
  139. #2339
    Dec 2015
    Quote Originally Posted by Starry Firmament View Post
    Reduce front tire pressure
  140. #2340
    Sep 2019
    thanks for your reply.
    my front tire pressure is 25 psi.
    for a 2.6" tire i think i can't reduce it anymore otherwise it will easily Puncture.
  141. #2341
    Dec 2015
    describe when you think its harsh. Speed, bump size etc. Im 165bs and use 18-19 psi with light instert in front tire
  142. #2342
    Sep 2019
    when going though on rock garden at medium speed. (high-speed compression)
    or on small rock,small pump at low speed.
  143. #2343
    Quote Originally Posted by nikon255 View Post
    Agreed, Iím also 165 and have Minion DHF 2.5 in front (EXO) without an insert, ride in rocky PA, and only have 16 PSI, I think you can go lower
  144. #2344
    Jan 2020
    Start with the HSC and LSC wide open and main/IRT pressures 8-10 psi under recommended. Then add LSC to taste.
  145. #2345
    Rocks belong
    Settings update for whoever is keeping track of these
    I've definitely got my COVID weight going right now... about 195lbs out of the shower
    I started with my Mezzer at 170 but the bike feels more balanced at 160.
    Main: 62PSI
    IRT: 95PSI
    Clicks from closed
    Rebound:4
    HSC: 2-3
    LSC: 5-6
    Love love love the way it keeps your front end up on steep, chunky trails that are full of stair step like rocks, roots and bombholes.
    Example: We shuttled Lemmon Drop in Tuscon yesterday and coming down the La Milagrosa trail you ride ride tons of STEEP rocky chunk.
    I've been trying to find my ideal air spring setup for several years now. I've ran Vorsprung Luftkappe, MRP Ramp and most recently had a Runt'd Lyrik before this (and have a Runt'd 36 on my hardtail)... I'm sold on the dual chamber positive spring systems.
    **Footnote**
    My setup is pretty progressive and I generally don't like uber plush forks... mainly, I love riding steep chunky trails and I hate a fork that dives a lot when you grab a bunch of front brake. The Mezzer is the best mix of plush and support I've found yet (my Runt'd and DSD tuned Lyrik being a close second).
  146. #2346
    Jun 2005
    Quote Originally Posted by ungod View Post
    This stuff?
    https://www.redlineoil.com/likewater-suspension-fluid
    So your basically tuning the viscosity of the oil in the damper? Any disadvantages there?
    Thanks in advance, interesting!
  147. #2347
    Quote Originally Posted by elsinore View Post
    This stuff?
    Yep! I had some lying around that I bought for a project years ago and never used. It was a big deal years ago on dampers that were not easily tuned, you could just throw some thinner fluid in the damper you had.
    I'm not really sure what the drawbacks or the current thinking on it is. The obvious would be that it's difficult to end up with a precise result. And of course it isn't cheap!
  148. #2348
    Rocks belong
    Whoops, I just realized I misspoke... my compression settings were clicks from open. Just edited.
    I prefer to run less compression damping and let the air spring provide the support. Having this option for fork setup is what I like the most about a dual chamber positive air spring.
  149. #2349
    Jul 2017
    Mezzer uses a parabolic LSC needle. Very nice.
    Is this step in the needle normal on the Mezzer LSC adjuster though? Or a machining issue?
    Attached Thumbnails Attached Thumbnails Manitou Mezzer-img_20201108_114421.jpg
  150. #2350
    Jan 2020
    That is interesting. I'm curious to see if anyone else finds the same, or if that is a defect. Sure seems like a shame to notch a nice paraboloid like that!
  151. #2351
    Apr 2015
    While we are on the topic - for those attempting to soften the damping on this fork, what has been the preferred method? Thinner damping fluid, removing a shim, both? I have read through most of this thread, but I would be curious to hear more of what folks have found working for them. Mostly I would like to end up in the middle of the range of adjustability on compression - to be able to open or close it up depending on terrain.
    For reference, I am at 170mm and tend to run HSC fully open (4 clicks from closed), LSC mostly open, and rebound mostly open at 8 clicks from closed. I am a tad bit softer on the air-spring side as well, but it still exhibits the support I prefer. I generally ride chunky, rocky, and semi-steep terrain, but this is my do-it-all bike that sees flatter/smoother terrain as well.
    I am about to do a service (100hr) mark and change up the bath fluid to Supergliss 100k as well. Given the recommendations, I wanted to try it out.
  152. #2352
    Reputation: Dougal's Avatar
    Quote Originally Posted by jcmonty View Post
    Remove the extra shim.
    www.dougal.co.nz
  153. #2353
    Sep 1999
    I know I've seen this somewhere in this thread but cant locate it...
    Can someone confirm the recommended setting are:
    CFC (click from closed)
    or
    CFO (click from open)
  154. #2354
    or
    Count lsc and lsr from closed as they are needle valves and closed is the only determined position.
    Count HSC from open as it introduces preload and open is the determined position.
    www.dougal.co.nz
  155. #2355
    Sep 1999
    Ok, that's a good way to remember.
    So just going by this guide for example:
    LSC Trail 1-4 CFC
    HSC Trail 3-4 CFO
    That is their intent?
  156. #2356
    Sep 2019
    how many shim should I remove in order to soften the damping?
    can I remove all of them?
  157. #2357
    Sep 1999
    See above post #2352....might help..
  158. #2358
    Jul 2017
    Pulled the wipers to get a better idea of bushing fit. One side slid well (csu would fall under it's own weight down the lower), the other was tight. Both stanchions in the lowers and the wheel mounted and it just got worse.
    After burnishing at 37.07mm, things are moving freely. The sticky side was noticably tighter during burnishing.
    Doesn't seem like Manitou has lowers and bushing tolerances figured out any better than Fox/RS.
  159. #2359
    Sep 2020
    Does anyone know if a QR 'maxle stye' axle is available for the mezzer? Does the Mattoc one fit?
    Seasucker bike rack + sports car = quite annoying getting the bike on/off without dropping the axle or an allen key on the car!
  160. #2360
    Quote Originally Posted by spicy View Post
    In theory the QR15 Hexlock could fit. In reality they're not in stock anywhere so I haven't been able to try.
    You would have to buy the QR15 and the dropout hardware to make it all fit.
    Owner of www.shockcraft.co.nz, Mech Engineer, Tuner, Manitou, Motorex, Vorsprung EPTC, SKF, Enduro
    www.dougal.co.nz
  161. #2361
    First. World. Problem.
    Sorry, couldn't resist.
    If you can find a boost axle I will donate the dropout hardware from when I swapped to the better system on my mattoc.
  162. #2362
    damned rocks...
    Reputation: Aglo's Avatar
    Dec 2014
    You have them in stock at Universal Cycles
    https://www.universalcycles.com/shop...s.php?id=84064
    If you are willing to wait I can do an empirical test in a couple of days.
  163. #2363
    Aug 2015
    Does anyone have any experience with the expert model?
  164. #2364
    Sep 2020
    I do occasionally encounter more serious problems than this!
    Thats very kind of you, I'll let you know how I get on finding an axle (out of stock on the universalcycles link provided).
  165. #2365
    damned rocks...
    Dec 2014
    On my phone the Boost version is in stock. Only the non Boost version is out of stock.
  166. #2366
    Sep 2020
    Good spot, I stopped scrolling a bit prematurely
    The prices to the UK are getting a bit silly including postage, import charges etc (£120+), so I'll keep my eye out for UK/EU stock and hold out for a while
  167. #2367
    May 2017
    Quote Originally Posted by mike156 View Post
    Yeah I don't think Manitou have their QC process dialed as yet. I've been running an Ohlins M2 fork the past few rides (switching between coil and air)and after fitting that it highlighted how tight it was getting my front wheel into the fork lowers of the Mezzer suggesting CCS86 was probably correct when he shaved the inside face of the lowers. Maybe an alignment tolerance issue there? The hub glides into the Ohlins with much less drama.
    In relation to quickly describing the fork differences...The way the Ohlins deals with repeated high speed square edge hits feels better than the Mezzer (both the air and the coil Ohlins feel more controlled). Ohlins seems to get out of the way upon impact quicker and recover quicker, feels unflustered. The Mezzer was good but there could be a feeling of getting hung up and the bike slowing down on repeated hits depending on the terrain.
    Braking over bumps on the Ohlins feels more controlled, much more so than the Mezzer. Ohlins feels like it's staying up higher in it's stroke under brakes but remains active (both the coil and air display this trait). The Mezzer felt like a trade off...if I got the rebound fast enough is this scenario it would feel skittish off the brakes. If i put more pressure in it to keep it higher I lost compliance.
    Bear in mind I am mostly splitting hairs here, they are both good forks and for me much better than any standard 36 or Lyrik that I've had. The extra stiffness of the Mezzer could be playing a part here, especially under brakes. Not sure about the accuracy of these figures below.
    From the first post in this thread by Mullen..
    'Torsionally, the Mezzer is 30% stiffer than a Fox 36, 16% stiffer than a Ohlins RFX36, 1% stiffer than a Lyrik
    Fore-aft, the Mezzer is 7% stiffer than a 36, 20% stiffer than a RFX, and 4% stiffer than a Lyrik'
    I've also removed a check shim and flipped the remaining one to reduce compression damping on the Mezzer. It's a tangible improvement to compliance and improved reaction speed. Feels like there has been an overall reduction in friction but still retains enough damping for my riding. If I hadn't been fortunate enough to try the Ohlins I would have been a happy camper.
    Both good forks but the QC of the Manitou is/was questionable (too early to tell with the Ohlins). So far with the Mezzer I've had 3 sets of lowers (current set has lasted the longest and seems to be a good one), one complete fork replacement, a replacement CSU and the damper side oil migrates up the damper side leg and stays there. Manitou have accepted all the issues but their comms are average and shipping replacement parts is slow.
  168. #2368
    Mezzer LE
  169. #2369
    Feb 2012
    Quote Originally Posted by hugelick View Post
    ... hmm, not for me. I think they might be going for some kind of vintage / throwback look, but personally, I'm glad forks are no longer silver.
  170. #2370
    Quote Originally Posted by ColinL View Post
    My buddy has a silver Pike on the bike he built his wife, I guess it's just a trend this year. Like all the strange colored Fox lowers, it looks very good on the right bike.
  171. #2371
    Mine arrived yesterday. Stickers are chunkier and it looks a lot sharper than that photo.
    www.dougal.co.nz
  172. #2372
    Aug 2015
    I think that might look pretty good with my raw aluminum frame.
  173. #2373
    Reputation: CCS86's Avatar
    Jan 2020
    There are two things at play there:
    • The paint applied to the axle cap flanges seems to be unaccounted for in the alignment stackup. It is a very small amount of thickness to remove from the stack. But, it does help the chassis friction to correct this.
    • The Mezzer has a wheel retention "feature". This, by far, is the reason the wheel feels tight when installing. The "ramps" leading the axle caps into the flange area aren't tangent with that flange. They form a perimeter wall that partially captures the axle caps. This makes it so you can remove the axle without the wheel falling out. It will stay in place without the axle. If you don't care about this, you could sand/file down this extra material, and the wheel would slot in easily.
  174. #2374
    Nov 2020
    So, pulled the trigger on one of these. I just hope it arrives with no damaged stanchions, with bleed ports, without binding issues, with no bend shims etc. etc.
    Supposedly it has more effective dampening than my Lyrik, where the dials don't really do anything. Crossing fingers!
  175. #2375
    Quote Originally Posted by boellefisk View Post
    Hey that's not true. The dials go full open (sort of works, but slow speed diving) to super shitty feeling.
    my bandaid is MRP ramp control for high speed compression and just deal with slow speed diving.
  176. #2376
    Aug 2015
    I don't see this color fork for sale anywhere. Where did you find this?
  177. #2377
    Sep 1999
    Talk to me about Mezzer Pro HBO Circuit
    From what I understand the Mezzer Pro HBO is hydraulic and 30mm.
    Seems like I get to the edge of the HBO on travel but never into it.
    Just for comparison I am 225lbs and on F36 & Lyrik I could get into that last bit of travel on my normal rides and especially on big g-outs.
    Does any part of the compression circuit HSC/LSC have any impact on HBO?
    Fork set at 150mm
  178. #2378
    Quote Originally Posted by Curveball View Post
    These were a limited edition run that is all sold out. Orders were months back when life was crazy.
    Pretty easy to replicate though.
    Attached Thumbnails Attached Thumbnails Manitou Mezzer-shockcraft-mezzer-chrome-insta5.jpg
    www.dougal.co.nz
  179. #2379
    looks like they have one silver 29, 180mm, 44 offset in stock here.
    https://www.universalcycles.com/shop....php?id=100021
  180. #2380
    Jul 2017
    Drew up a fork seal driver to have printed after seeing the Manitou driver is $50. Anybody else interested in one? Cost of materials and shipping is all I'd be taking.
  181. #2381
    Nov 2020
    Can't they just be pushed in by hand like RS seals?
    But yeah, I'd be interested in it, but I guess it isn't practical since you are US based, right?
  182. #2382
    $1,099? That is an expensive paint job! I like my black Mezzer even more.
  183. #2383
    Aug 2015
    Thanks much. My bike is 27.5 though and I think a black one will be fine.
  184. #2384
    I'd be interested. Guess i'll need it eventually.
  185. #2385
    Mezzer seals also fit a BOS fork. I've had my stock cleaned out a few times by people needing them.
    www.dougal.co.nz
  186. #2386
    Sep 1999
    sure, +1
  187. #2387
    Mar 2011
    For sure, would be greatly appreciated!
    Memory hazy but did you also make the wrench for marra pro air can?
    Sent from my SM-N986U using Tapatalk
  188. #2388
    Reputation: Velodonata's Avatar
    May 2018
    Yup, count me in.
  189. #2389
    Jan 2020
    Quote Originally Posted by croakies View Post
    That's me.
  190. #2390
    Jul 2019
    Yes, that would be great!
  191. #2391
    Boom bap ambassador
    Why hell yes I would be interested in a seal driver, count me in
  192. #2392
    Jul 2017
    They seem to be tighter/stronger then RS seals I've done as I'm not able to just push them in by hand.
  193. #2393
    Yes please. Count me in.
    Pole Evolink 140
  194. #2394
    Apr 2015
    Me too! Thanks for the initiative!
  195. #2395
    Jul 2017
    An estimate of the HSC shim stack preload and some different springs from rotorclip. The MWL all have roughly the same rate in a given diameter. The last letter is the height, so the longer springs add preload. MWM is a stiffer spring (the stock spring is roughly MWM-14 B, (shorter and stiffer). I think the MWL-14 C is the most intersting as it has VERY LITTLE preload in actual use and in the stiffest position is about 1 click out from fully hard compared to stock.
    FWIW, they do not stock the flat (shim) faced versions of these springs. However, they sent me some samples of the springs without flat faces and they look like they will work fine. It might be possible to get the flat face version as a bulk order though. The part number changes a bit depending on the material selected.
    MWL-14SQ CF - stainless, flat faced
    MWL-14ST CF - steel, flat faced
  196. #2396
    Jul 2017
    Compression basevalve lapped with 1000 grit then 1500.
    Upper right - original
    Upper left - this was actually a decent amount of the way in. Maybe 60% of the total lapping effort.
    Lower left - 80%
    Lower right - final after 1500 grit
    Feature (dished) or manufacturing???
    Attached Thumbnails Attached Thumbnails Manitou Mezzer-20201118_211032-collage.jpg
  197. #2397
    Nov 2020
    Then I'd be very interested. How do you get them out? Can you just pry them loose with a flathead screwdriver?
  198. #2398
    Jul 2016
    I would like to get in in this as well, please and thank you!
  199. #2399
    Reputation: otsdr's Avatar
    I use a driver made by Unior, works just fine. https://uniorusa.com/collections/sus...ion-guide-1702
  200. #2400
    Reputation: spo0n's Avatar
    Nov 2020
    Quote Originally Posted by otsdr View Post
    I have used the 35/36mm one on a 36. was a really loose fit in the seal, nothing like the RS one on RS seal. i can see this working
    "Why are you just watching?
    Why donít you fight!!"
Page 12 of 13 FirstFirst ... 28910111213 LastLast
  1. Manitou Mezzer Long Travel fork spotted at Sea Otter
    By Dougal in forum Shocks and Suspension
    Last Post: 05-06-2019, 08:59 AM
  2. Manitou Minute vs Manitou R7?
    By Numbtoyou in forum Shocks and Suspension
    Last Post: 04-19-2015, 04:25 PM
  3. Replies: 6
    Last Post: 07-20-2013, 09:02 PM
  4. Will my Manitou Air reducers fit a Manitou Coil?
    By ixi in forum Downhill - Freeride
    Last Post: 07-11-2005, 10:05 AM
  5. Manitou Black vs Manitou Splice?
    By CircuitMan in forum General Discussion
    Last Post: 03-28-2005, 10:59 AM
Members who have read this thread: 739
