Manitou Mattoc 29+ travel spacer question...- Mtbr.com
    gluttons
    Oct 2007
    Has anyone taken out 1 more spacer then they should have to gain another 10mm travel on a 29+ Mattoc Comp. The fork supposedly came on my bike in it's 110mm travel option. I took the fork apart after purchasing a tool kit from Manitou so that I could increase the travel to 120mm. The manual from Manitou states 2 spacers for 120mm travel on a 29+ fork. I expected to find three spacers, since that would indicate to me via the technical information that the fork was set at 110mm but I only found 2 spacers. I removed another spacer, which I am sure is not recommended and gained another 10mm travel. I am curious if anyone else has done this/ridden their bike and what the results were...
    Reputation: Dougal's Avatar
    Mattoc 29+" aftermarket forks could go to 120mm. OEM will depend on whether they ran the same stanchions and rod length.
    Owner of www.shockcraft.co.nz, Mech Engineer, Tuner, Manitou, Motorex, Vorsprung EPTC, SKF, Enduro
    www.dougal.co.nz
    gluttons
    Oct 2007
    Quote Originally Posted by Dougal View Post
    Thanks for the reply Dougal. I was told that I could increase the travel of the fork to 120mm from the bike manufacturer. There were 2 spacers in there. I took one out and increased the travel by 10mm. Do you know anyone who has done this? I realize that it is most likely not recommended but I am curious? Fork is measuring 130mm travel...
    gluttons
    Oct 2007
    So if anyone else is considering this in the future...Not advisable. Bushing play.
  1. Can you increase the travel of a manitou mattoc comp 29+ 110mm
    By jaggittens in forum Shocks and Suspension
    Last Post: 08-04-2019, 11:42 AM
  2. Manitou Mattoc Comp 29+ fork for sale.
    By mikesee in forum Classifieds
    Last Post: 07-18-2019, 12:43 PM
  3. Manitou Mattoc Comp vs. Manitou Machete Pro vs. Suntour Axon
    By richj8990 in forum Shocks and Suspension
    Last Post: 03-29-2019, 04:49 PM
  4. 2017 Manitou Mattoc Pro 27.5+/29 fork ?
    By keen in forum Shocks and Suspension
    Last Post: 03-07-2019, 07:56 PM
  5. Mattoc pro vs Mattoc comp
    By 2old in forum Shocks and Suspension
    Last Post: 08-28-2018, 08:44 PM
Members who have read this thread: 18
