Magura Odur servicing- Mtbr.com
Results 1 to 2 of 2
    From the Magura service manual
    We recommend cleaning your fork on a regular basis. Use water, mild soap and a brush. Do not use a power washer as water may
    be forced through the seals, destroying them, the internals, bushings and stanchions.
    Check monthly below the dust scrapers and clean if necessary. Remove
    the dust scraper carefully with a screw driver blade, clean the
    space below the scraper and install it again with certain pressure.
    Simple maintenance
    The oil marks on the stanchions of my second hand Magura Odur have disappeared, and the fork has become noisy.
    Can the dust scrapers be removed without taking the fork to bits, and then oil added into the foam? The service manual below shows oil going in at the bottom of the legs.
    Basic maintenance
    2009 service guide here but it's in French and the Odur isn't mentioned http://www.magura.com/uploads/media/...ce_de_base.pdf
    The manual lists Suspensionblood Type 5 which assuming part number is constant (code: 0731 121) is ISOVG 100 / SAE 40 ( http://www.birota.ru/manuals/magura/...003-levels.pdf ) / Suspension Blood type 5 (for lubricating oil under leg and air chamber, Order No. 0731121)
    http://www.magura.com/de/produkte/fe.../info/faq.html
    What ISOVG 100 / SAE 40 oil could be used other than buying the suspension blood 5?
    Kind regards,
    Ashley.
    Bike Geek
    Reputation: norcalruckus's Avatar
    May 2005
    magura website
    I would try posting the above on the magurausa.com website forum,
    RIP AL DAVIS
